Old 02-17-2008, 11:32 AM   #1 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile injector pump leaking on vw diesel
the shaft seal on my IP started leaking, and i went my local diesel injection service and bought a new seal for like 7 bucks. and althought it is not suppose to be possible, i took off the pump pulley while still in the car, picked out the old and drove in the new seal, it ran for several years and began to lose prime over night. so I installed one these after market little thumper 12v fuel pumps just before the filter. thinking i could just turn it on while i was starting in the morning to prime the IP and then go on. but i didn't have to turn it on cause it has a check valve in it and the car has run perfect ever since. see pic.
Old 02-18-2008, 01:31 AM   #2 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
the injector pump loosing prime like that is apparently from the timing belt not being tensioned correctly, the pump has a simple bushing and if the belt is to tight it will wear it out, not sure if the bushing can be replaced, but the seal is a good fix! better then shelling out $1,000 for a new injector pump, or $700 for a used on, I think I paid $11 for that same seal incase I get the rabbit running.
Honda's with carburators have a brass check valve in their fuel line too... never checked on what exacty it does...
Old 02-18-2008, 04:33 PM   #3 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Bushing's $5-10.
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 01:22 PM
Wanted (1st gen VW turbo diesel) 3lr For Sale 19 10-28-2008 04:28 AM
Diesel Metro? michigandiesel EcoModding Central 17 10-16-2008 11:45 AM
News: Only 6% of Americans think diesel will succeed as powertrain option MetroMPG General Efficiency Discussion 38 02-14-2008 03:23 AM
i-dtec (Honda Diesel) RH77 EcoModding Central 22 02-11-2008 02:20 PM
