The point isn't to down size injectors. He's just trying to find an EV6 in the 12-13# range. The capacity of the engine is irrelevant.
A few options:
0-280-155-604, VW 2.0 8v, 13.1#
0-280-155-707, ford, 12.9#
0-280-155-708, ford 12.9#
0-280-155-756, ford, 12.7#
0-280-155-846, ford 4.0 V6, 12.9#
0-280-155-962, ford, 12.7#
Any of these should work, they don't have to be the exact same flow rate. Just make sure they are the correct length and correct electrical connector. If you want to make sure that the engine adapts to the new injectors quickly, replace your O2 sensor at the same time.
good luck
