Old 07-17-2015, 02:12 AM   #1 (permalink)
Injector wiring tapping point confusion
Hello, I'm thinking of fitting a MPGuino to my motorcycle (Suzuki TL1000R) and I'm unsure where to tap into the wiring loom. It has 12V supplied to the 4 injectors all the time and uses (I assume) NPN transistors to switch on the low side of the circuit. My concern is that if I tap in after the injector (closer to the ECU) I'll complete the circuit and cause the injector to open. Therefore I think I should tap in to the wiring before the injector and create the completed circuit before the injector and this would leave it to be controlled by the ECU. Am I right, wrong or paranoid? Also can someone confirm the ohms of the resistor as 100K or 50K.
Cheers
Mike
Old 07-17-2015, 11:50 AM   #2 (permalink)
12V/100k = how many amps? (hint: not enough to turn on the injector )
Old 07-17-2015, 09:28 PM   #3 (permalink)
Hi and thanks for the reply. Yes, I hadn't considered that point, I was worried about the injector being on all the time.
Cheers
Mike
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
