Old 02-25-2010, 12:12 PM   #41 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
If that signal is anything like what the ECU reports in VAG-COM, it's not accurate at all (overly optimistic at low rpm and pessimistic at high rpm).
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 08-22-2010, 03:22 AM   #42 (permalink)
Did anyone ever successfully find where to tap the MPGuino into a TDI? I.e., anyone besides yetimus & others who were lucky enough to have a Fuel Consumption signal from their ECU. My 98 A3 TDI doesn't have that signal (harness is missing that wire), and i assume only some Passats actually had it.
Old 05-20-2011, 02:46 PM   #43 (permalink)
I'm also interested if anybody ever got this to work with their USA TDI.
Old 05-20-2011, 03:05 PM   #44 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
I gave up and installed a MFA
I still need to add the Outside temp Sensor, but I have replaced the panel missing in that pic and re-installed SGII.
If you need any support with that, let me know I'll post up what I know.
6 speed ALH TDI
Old 05-20-2011, 04:21 PM   #45 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Hmm, it is displaying mpg, but no "light blue wire" for the fuel consumption signal?
Old 05-20-2011, 04:26 PM   #46 (permalink)
6 speed Diesel FTW!
Diesel
The light blue wire does supply signal, however when I probed it with Oscilloscope it had no correlation to my assumed fuel consumption.
I assume it is some other type of signal that is not obvious unsung an oscilloscope, or the MPG Guino.
What is installed in the car now is a different cluster, mine is from a Bora TDI sport (which happened to be a 6 speed), I assume it uses the blue wire for fuel consumption . . . .
6 speed ALH TDI
Old 04-30-2012, 03:51 AM   #47 (permalink)
Quick answer for you, nick:
Add a wire to your T68 ecu harness connector, at pin #9. I recommend you de-pin one from a junk yard harness, and add it to yours. (Note: depinning VW harnesses is a b-word). Now run it through a rubber plug in the firewall, near the fuse block. You'll need to remove the 100k resistor from your mpguino, because the signal is low-voltage and does not need to be pulled down. Keep the zener, though.
Next, get your VSS signal from the blue/white (or white/blue) wire at W/1 on the fuse/junction block. It's a 12v-0v signal, so keep the corresponding 100k resistor on the 'guino.
Set your InjTrg to 1 (Rising). As for other settings, i haven't calibrated mine yet. My ballpark guess is around 13000 VSS/mile, and 170,000,000 usec/gal, with maybe a 100 usec InjDelay. But i wont know until after i've burned a few tanks.
Good luck.
P.S. kick yourself for not following through with this 2 years ago.
Old 04-30-2012, 11:01 AM   #48 (permalink)
I always like how speedometers are 1/2 useful and 1/2 wasted space. 160mph for that TDI? That's a little overkill.
Old 05-10-2012, 07:48 PM   #49 (permalink)
Good luck.
What is pin 9 on the ecu? Is that the fuel consumption wire that was never run to the dash on the US 1999.5+ tdi?
Old 05-10-2012, 08:15 PM   #50 (permalink)
yep. the MFA signal. 99+ don't have it? Mine didn't have the wire either, but i added it to the harness, and now i'm getting it from the ecu. Isn't there a thread on here about someone's 2001? Maybe that's the one that devolved into speculation of using the Lift Sensor, or this or that other signal.
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
