Old 12-18-2008, 10:42 AM   #1 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Instead of vacuum gauge: multimeter on MAP sensor
Just had a thought - probably not original:
Instead of buying a vacuum gauge, another option is to wire a cheap multimeter to the MAP (manifold absolute pressure) sensor (if your car has one).
It wouldn't be too hard to drive a little bit and see what voltage corresponds to the lightest load, then use it as a relative indicator of fuel consumption. Very useful if using the DWL (driving with load) technique.
Maybe make a simple LED array that does the same thing, so you don't have to read numbers.
Old 12-18-2008, 11:21 AM   #2 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
wasn't there some talk recently of MAPs having a frequency output as opposed to V output?
Old 12-18-2008, 11:26 AM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Most MAPs have voltage outputs. I'm sure some maker somewhere thought they'd be smart and put in a frequency output on something though.
Old 12-18-2008, 12:09 PM   #4 (permalink)
Right - joelmaldonado used a Ford frequency output MAP sensor for his load-smart cruise control: Cruise Control (with MPG sensitive logic)
And I just remembered where else I've seen a MAP sensor + multimeter as instrumentation: Test: F-150 pickup "cap on" vs. "cap off" @ 60 mph
Ironically, they were using a Ford, so bought a junkyard GM MAP sensor to take relative readings of engine load during their tests.
Old 12-18-2008, 12:42 PM   #5 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
TDI MAPs are 0-5v. But then again we don't run under vac. It's useful to get the load though.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 12-18-2008, 12:45 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I took some readings off the metro map sensor that coyotex sent. I used an atmega168 to turn 5 volts into a 0 to 1023 number, but a voltmeter on 5 volt scale would do fine too (for a geo):
Reading a MAP sensor
I really have no idea how many cars use pulses vs sensors or what all the pinouts are or the signals or voltages involved might be though.
Oh, and an analog meter would be nice for vacuum.
Old 12-19-2008, 03:13 AM   #7 (permalink)
Custom User Title
Daily Driver - '02 Grand Prix SE
90 day: 18.45 mpg (US)
I "think" my 95 sonoma has a map sensor. Anyone confirm? 4.3 CPI motor(92-95), not TBI or CFSI (96+ only).
I don't think the GP has one though, and that's my highway cruiser.
Old 12-19-2008, 03:19 AM   #8 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Firefly 3dr
90 day: 40.08 mpg (US)
I did this with my acclaim. I found that the dmm I was using, having 1/2 second measurement, wasn't responsive enough. Something a bit faster, and it would work great.
Old 12-19-2008, 12:43 PM   #9 (permalink)
dichotomous's Avatar
CivySi - '03 civic SI
90 day: 31.99 mpg (US)
I like this idea, one two wire cord coming into the cabin and my multimeter would make a good proof of concept and load indicator, very nice idea, I will likely try this sometime this weekend
Old 12-19-2008, 12:53 PM   #10 (permalink)
Cool - let us know how it goes.
Best spark plugs / wires with FE in mind? noopy7 EcoModding Central 12 10-29-2010 03:18 PM
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 03:53 AM
My Kingdom for a NOx Sensor cfg83 EcoModding Central 19 08-25-2010 06:55 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
no vacuum for vacuum gauge? modmonster Instrumentation 2 11-07-2008 07:40 PM
