09-22-2016, 01:44 PM
#2211 (permalink)
Heckmotor ist am besten Motor!
That is one sweet Mercedes, although I'm not partial to red.
Mercedes-Benz 150 (W30)
The Mercedes-Benz 150H was a prototype sports racing automobile built in Germany in the 1930s.[1] It was derived in 1935 from the 130 with only two seats and a more powerful engine, with 1498 cc and a power of 55 PS (40 kW). The top speed of the car was 125 km/h.
Conceived by Hans Nibel, chief engineer of Mercedes-Benz,[1] the 150H was inspired by Edmund Rumpler's Tropfen-Auto. It followed on the Rumpler-chassis Tropfenwagen racers, which ran between 1923 and 1926,[2] and was based on the backbone chassis of earlier 130H.[1]
https://en.wikipedia.org/wiki/Mercedes-Benz_130
https://en.wikipedia.org/wiki/Mercedes-Benz_in_motorsport#1923-1939
Edit: Not air cooled.
While the 130 had a 1.3-liter, water-cooled four hung out behind the rear axle, the 150's 1.5-liter four was turned around 180 degrees, its midships location giving the chassis better balance and more stable handling. In place of the 1.3-liter's sidevalve arrangement, the 1.5 had overhead valves, and produced about 55 horsepower with a Solex two-barrel carburetor and a compression ratio of 7.1:1.
http://www.hemmings.com/magazine/hmn/2010/04/1935-Mercedes-Benz-150-Sports-Roadster/2998941.html
09-23-2016, 08:11 AM
#2212 (permalink)
In the future, we will all be driving aerodynamic automobiles.
Yes, we will still be driving ourselves, and there are going to be some accidents along the way.
Images for > Rumpler Tropfen Auto
Looks like they used standard intersections, maybe a traffic circle or round-a-bout in the air would have been better?
Found doing a Google image search using the phrase " Tropfen-Auto".
09-23-2016, 08:51 AM
#2213 (permalink)
That is a reliable source of automotive information, however the original German website may have been mixing and matching different eras and photos with different models to tell a ( complex) story.
The "H" model has an interesting history to say the least.
Using Google translate on paragraph after paragraph was getting tiresome, so I simply translated the word "air-cooled" and found this passage.
Die Mercedes-Benz Heckmotor-Fahrzeuge der 1930er Jahre - Initiative Kulturgut Mobilität
Are also formed between the end of 1931 and 1934, numerous designs of small four-seat rear-engine car with air-cooled boxer engines and liquid-cooled three- and four-cylinder engines, which are placed partly in cross motors on the rear axle. Parallel to this in the same size category as well as vehicles with a front engine and front wheel drive, in this combination downright groundbreaking. Kissel encourages the front engine design, where appropriate, to have a replacement for the rear-engine car.
The vertical four liquid cooled in the red car may have an air-cooled engine style shroud ducting air to an enclosed radiator. Hence the misleading or confusing photos requiring some sort of deciphering.
Air-Cooled = luftgekühlt
Below are the two images I consider requiring some sort of explanation:
Again, I suspected these are positive or perhaps negative air pressure ducted air enclosures pushing or sucking air through the rear mounted radiator.
I consider this to be a very efficient and aerodynamic advancement.
It is not often we look under the hoods of cars in the aerodynamic forum, this case study affords us this chance.
NOTE-1: The two photos above I think show some experimentation in packaging of the air-duct and radiator location.
The wishbone frame top one looks to be a bottom discharge.
The close-up second photo a rear discharge or the far side we cannot see discharge.
I suspect the boatail roadster used the bottom discharge.
I suspect the sedan/coupe used the side/rear discharge layout.
I also could be wrong, it's just the way I would have done it considering the body shapes involved.
Note-2: These are clearly two different engines and transmissions, and probably two different model variants from which they come from.
09-23-2016, 12:29 PM
#2214 (permalink)
A modified version of the Mercedes 'H' chassis was used in the Schlörwagen (aka Pillbug):
I believe that version is water cooled with a ducted fan cooling design for the radiator. I think these were designed by Dr Porsche, and they had the swing axles - which means the Schlörwagen was probably a handful to drive.
09-23-2016, 11:21 PM
#2216 (permalink)
Possibly the world's most aerodynamic 1924 Oldsmobile?
I gotta say, that is *****in!
09-24-2016, 01:17 PM
#2217 (permalink)
air-cooled
Originally Posted by kach22i
might be liquid-to-air-cooled.
09-25-2016, 07:01 PM
#2218 (permalink)
The shrink wrap I used on my Aero Tonto made this semi look aero
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
09-25-2016, 08:45 PM
#2219 (permalink)
Everything is liquid to air; your choices are water or oil.
