Old 02-13-2018, 10:31 AM   #2571 (permalink)
Kingcycle: Wheel Spats Part II
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
freebeard (02-13-2018), NeilBlanchard (02-13-2018)
Old 02-13-2018, 12:17 PM   #2572 (permalink)
Well, those wheels spats are for a track vehicle - they have virtually no ground clearance, whatsoever.
Old 02-13-2018, 02:55 PM   #2573 (permalink)
It needs air bags.
Walk without rhythm and it won't attract the worm. --fatboy slim
_________________
Old 02-13-2018, 09:00 PM   #2574 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
C - '97 Vision R40
minivan - '93 oldsmobile Silouette
Tracker - '96 geo tracker 4wd 2d soft top
90 day: 30 mpg (US)
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
Grant-53 (02-14-2018)
Old 02-14-2018, 12:46 PM   #2575 (permalink)
Anyone in a vehicle traveling above 30 mph on the open road would benefit from a restraint system. Perhaps 40 mm spat clearance is enough for road use.
Old 02-14-2018, 12:48 PM   #2576 (permalink)
Posted in the forum a few years ago, my first time seeing it.
2009
Cd and blunt front ends
A nice collection of aero-caps for pickup trucks:
http://jaziza.blogspot.com/2012/10/
Chin Spoiler:
Roof Wing
aerohead (02-17-2018), BamZipPow (02-14-2018)
Old 02-14-2018, 10:09 PM   #2577 (permalink)
Your second picture is of the Blowfish. It's in the same league as the Stupidbaker:
_________________
Old 02-14-2018, 10:24 PM   #2578 (permalink)
They talk about the great applications for curving polycarbonate for aerodynamics, then produce this as the proof of concept.
October 22, 2014
Concept EV uses LEXAN windows to boost range
https://chargedevs.com/newswire/conc...o-boost-range/
The concept vehicle, developed as part of the Visio.M (Visionary Mobility) project, uses windows made of LEXAN resin, a polycarbonate (PC) material made by Saudi Basic Industries Corporation (SABIC). Compared to conventional glass, using the LEXAN windows reduces weight by over 13 kg and extends driving range by up to two km. Polycarbonate’s superior insulating properties reduce demands on the car’s heating and air conditioning system, and make possible up to 15 additional kilometers in extended range. The concept EV weighs 450 kg (without battery), and has a 15 kW motor.......................
Current European regulations permit PC to be used for all automotive windows except the windshield.
Looks fairly aerodynamic, kind of.
Those wheel flares are pure drag.
Your second picture is of the Blowfish...
The first picture of the silver belly pan is also that car, and the reason I posted it at all.
Chin Spoiler:
Roof Wing
Old 02-15-2018, 12:17 AM   #2579 (permalink)
Got to pad your bra to get news sites to post your pics.
Old 02-15-2018, 01:45 AM   #2580 (permalink)
...Unless widening the body to fit the track would add frontal area. Putting a wide body on a car designed for a narrower track is what we're used to seeing.
The Saudis are turning petroleum into glazing?
'Up to' seven times the saving from insulation vs weight savings?
992lb/20hp? It's a flyweight
I included the first picture, then edited it out because I couldn't be completely sure.
_________________
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
