02-28-2018, 08:38 AM
#2621 (permalink)
Originally Posted by Frank Lee
Thanks for the link Frank Lee.
From his first entry:
It will be an ongoing project that probably won't end until the car is completely destroyed.
At least he had a good sense of humor about it, and hopefully still does.
03-06-2018, 03:55 AM
#2622 (permalink)
https://www.theverge.com/2018/3/5/17...ile-range-2022
I'll leave it for others to fit The Template to this. I'm more concerned with the underside nowadays. I used a combination of scrolling the bottom of the screen to low point of the front valance and a plastic ruler to find the dimensions are 5/8" rise over 14".
According to https://www.calculator.net/triangle-...s=d&x=122&y=21 the undercarriage has a rake of 2.56°. Or at least that swage line. The undercarriage appears to be half that at the rear wheel and then bells up.
03-06-2018, 12:41 PM
#2624 (permalink)
VW has a very satisfying design sense, in my opinion. They have distinctive, yet smooth designs; that are low drag - or at least they prioritize low drag.
03-06-2018, 01:26 PM
#2625 (permalink)
Too bad they're connected to VW engineering and manufacturing.
03-06-2018, 01:28 PM
#2626 (permalink)
...beats walking...
Chassis reminds me of the 2002 "skate-board platform" that GM had hyped...then dropped: https://www.autoblog.com/2010/09/24/...2-gm-autonomy/
03-06-2018, 02:10 PM
#2627 (permalink)
Chassis follows Tesla, body follows Aston Martin via Tesla. They're converging to a type.
Frank Lee — So long as they don't use these:
https://duckduckgo.com/?t=palemoon&q=VW+Beetle+fuse&iax=images
03-07-2018, 12:24 AM
#2628 (permalink)
Speeeking of Aston Martin... The Aston Martin Valkyrie AMR Pro has an interesting diffuser:
https://www.gtplanet.net/aston-marti...xtreme-enough/
It's hard to see in the thumbnails, but the outer fences are canted and diverge on the interior. I'd call them skegs. They [conform to][confirm] my own thinking.
They are also bi-plane like F1 front wings.
03-07-2018, 09:00 AM
#2629 (permalink)
If I remove the rear wheels and imagine this form as a boat moving through the water I want to turn those things into movable rudders.
However those giant rear wheels and the turbulent drag they create are going to stay.
Could these oversized, overly divergent rear diffusers be taming the air both sides of the fences?
That is to say, yes the higher pressure lower speed of the air exiting from underneath the car because of divergence is one aspect, but there is also something happening off to the outside and behind the rear wheels.
https://www.woorank.com/en/www/wirthresearch.com
Just a random CFD image above to illustrate that rear turbulence.
03-07-2018, 03:09 PM
#2630 (permalink)
I'm always referring to this picture from Bonneville. I should have taken more. The fence is vertical and wraps out from the inner face of the tire to the outer face. If the tips were flaired out it would match Aston Martin's design.
Think shuttlecock.
