Old 08-19-2009, 08:26 PM   #1 (permalink)
Red Wrangler - '98 Wrangler Sport
90 day: 15.67 mpg (US)
Wife's car - '01 Sentra GXE
90 day: 29.31 mpg (US)
Interesting alternative fuel
This sounds like a really interesting alternative fuel:
AOPA Online: Grass for gas
Seems to be marketed towards aircraft, but it doesn't look like there is any reason it couldn't work it a car too. I'm curious how these guys will do.
Old 08-19-2009, 09:43 PM   #2 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Switchgrass ethanol.
Probably didn't say the word "ethanol" because so many have a knee-jerk reaction against it.
Old 08-20-2009, 12:16 AM   #3 (permalink)
Specifically says in the video not alcohol based. Wouldn't think they would be so confident in using it in unmodified aircraft if it was ethanol. The FAA would have difficulty certifying that because ethanol picks up water and also tends to eat some kinds of fuel lines. They'd probably require you replace the whole fuel system in some planes. Plus, tends to reduce fuel economy because of reduced BTUs. The test pilot got the same fuel burn as 100LL. Recall info about running aircraft engines on ethanol, I think they increased fuel burn by 20-30%.
Old 08-20-2009, 12:43 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Problem is they don't bother saying exactly what it is, and so we can't tell how much is marketing tripe and straight up B.S.
But if anyone wants to play detective, and make some major assumptions about the validity of the claims:
Clues? the "Swift Fuel" stuff:
smells like a musty old locker room
is 104 motor octane
created from millet,switchgrass,sorghum,garbage?
Not ethanol, "don't have alcohol in the fuel"
Can use and retrofit an ethanol type facility.
Mixes with avgas
EGT is higher and CHT is cooler.
6.5 lbs per gallon, vs 6 lbs for avgas
meets/exceeds performance of 100ll without engine mods.
Hope that helps
Old 08-20-2009, 12:48 AM   #5 (permalink)
Smell would rule out alcohol it would seem. I remember somewhere reading it was technically possible to synthesize gasoline type hydrocarbons out of plant material. Can't be a form of biodiesel, since it runs in gas engines.
Old 08-20-2009, 02:47 AM   #6 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
I suspected butanol, but that is 6.76 lb/gal. Perhaps a mix with that?
Old 08-20-2009, 02:56 AM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
I'm liking butanol as a major component, can be made from scrappy biomass, musky odor, gas engines can use up to 85% mix without modification, pretty close on the density...
Technically an alcohol, but willing to let that one slide as a verbal typo (speako?).
Old 08-22-2009, 05:37 PM   #8 (permalink)
I also immediately thought butanol. The smell would be the big tip off.
If true, butanol would have a somewhat better return for energy invested compared to ethanol from corn, but nothing close to biodiesel, and not an earth changing fuel.
On the other hand, we can't get fixated on a silver bullet answer that fixes all energy problems. There isn't one. So, I've got room for a few cellulosic butanol plants if the math really does work out right.
Finest regards,
troy
Old 05-16-2010, 09:22 AM   #9 (permalink)
noxman's Avatar
I prefer Butanol too. Butanol is less aggressive than ethanol, have over 30% heating power than ethanol and very low emissions. Only one minus. Problem with starts in winter or colder places. But i guess, engineer can find fix this problem.
Second thing is that, Opec don't disagree.
http://www.butanol.com/
Butanol fuel - Wikipedia, the free encyclopedia
1.Fiat Punto 1.1 8v 40 Kw - 1996. 4l/100km with external board computer http://www.youtube.comwatch?v=P0Eq_m1VhBQ
2.Fiat Punto 1.2 8V 44kw - 2002, LPG injection system, trying to be eco... Video shows my lpg system and ride.
http://www.youtube.com/watch?v=FlQ-Xl6aIj0
Old 05-16-2010, 03:39 PM   #10 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
Here's another article on it. They are planning on doing away with Leaded aircraft fuel so folks are strating to look for alternatives.
GA and the Environment: Plant Power
What's the answer to avgas?
By Dave Hirschman
The original claims describing a bio-fuel replacement for avgas sounded too good to be true.
Swift Enterprises, a small start-up firm in Indiana, announced last year that it had developed an unleaded, domestically produced, higher-octane aviation fuel that could be manufactured and produced at a far lower cost than avgas. It promised its bio-fuel would reduce emissions 20 percent and increase aircraft range up to 15 percent.
Laboratory tests by the FAA confirm that Swift’s avgas replacement will work in current piston aircraft engines, even the high-compression, turbocharged varieties that are particularly susceptible to detonation. (Teledyne Continental Motors has begun flight tests using Swift fuel.) The bio-fuel burns cleanly, has acceptable vapor pressures, and even offers some range and performance advantages over traditional avgas. So far Swift has only produced its product in tiny batches. And the unit costs for making it that way are extraordinarily high.
U.S. refiners currently sell about 250 million gallons of leaded avgas a year. That may sound like a lot, but it’s far less than a day’s production of unleaded auto fuel. The world’s aviation emissions—including airlines and military jets—account for about 3 percent of all carbon-dioxide emissions, and general aviation is a tiny fraction of that amount. But avgas is one of the few fuels that still contain lead, and a combination of new regulations, environmental considerations, and economics may soon make leaded fuels untenable.
Swift plans to use switchgrass as its fuel source. An abundant, fast-growing plant that used to cover much of the American heartland before corn, soy, wheat, and other crops took over, switchgrass has a higher energy output than food crops, and using switchgrass in bulk won’t drive up food prices. Swift is building a manufacturing facility near Purdue University Airport in Indiana where company officials hope to prove the merits of high-volume fuel production.
Since Swift fuel is unleaded, it can travel in the same delivery pipelines refiners use to deliver auto gas. Avgas must be segregated from other petroleum products throughout the production and delivery process and stored in separate containers. Trucks, rail cars, and vehicles that carry leaded avgas can’t be used for unleaded fuels. Swift officials say they expect some cost savings based on its ability to use the existing transportation infrastructure for other unleaded fuels. FAA certification of Swift fuel, or any other bio-fuel, is likely to take several years at least. While Swift pursues FAA approval, it’s also selling its specialized fuel to car, motorcycle, and even air racers willing to pay a premium for the added performance they say it brings.
Diesel aircraft engines got a black eye last year when German manufacturer Thielert sought bankruptcy protection after the founder was accused of financial misdeeds. The company’s troubles dealt a serious blow to Diamond Aircraft and other aircraft manufacturers that depended on Thielert for a steady supply of engines and parts, as well as owners of aircraft with Thielert engines. Cessna had already announced plans to manufacture Thielert-powered 172 Skyhawks for the world market when Thielert imploded.
But despite the turmoil Thielert caused the GA industry, the company proved that modern diesel engines are technically feasible, and there’s a demand for the relatively simple, highly efficient powerplants that can run on kerosene-based jet fuel.
Diamond has partnered with Austro Engines to replace Thielerts on its ultra-efficient DA42 twins. Also, French manufacturer SMA is continuing its certification efforts for its own purpose-built diesel engine that has logged many hundreds of test hours in a Cessna 182 and Maule aircraft. U.S. engine manufacturers Lycoming and Continental have studied diesel engines intensively, although neither has brought one to market.
The simplest solution to moving away from lead in aviation fuel would be to continue manufacturing avgas—but without the lead. Such a fuel is currently produced in Europe as 91/96UL and about 70 percent of the piston-powered U.S. aircraft fleet could use it today without any engine or airframe modifications. Piston aircraft engines don’t require lead for lubrication. It’s there to raise octane levels and prevent detonation in high-compression and turbocharged engines that operate at elevated temperatures and internal pressures.
Such high-compression piston engines comprise about 30 percent of the current U.S. piston fleet. But because they are typically found on business aircraft that fly more often and consume more fuel on an hourly basis, those engines account for roughly 70 percent of avgas sales. AOPA has long been committed to finding a single fuel that can serve as a safe, reliable avgas replacement for the entire piston fleet. Petroleum producers and aircraft engine manufacturers have been experimenting with unleaded avgas and say the results are encouraging. But they haven’t announced plans to approve it for everyday aircraft use.
U.S. engine manufacturers and aftermarket firms have long been studying electronic engine controls that would allow piston aircraft to operate on today’s avgas, auto fuel, or any combination of the two. None of those efforts have produced a product ready for FAA certification yet—but such tools may be getting close.
George Braly, founder of General Aviation Modifications Inc. (GAMI), has said he plans to fly an aircraft with a turbocharged, high-compression engine using unleaded fuel and electronic controls to a major aviation event this year. GAMI has long been developing an electronic system known as PRISM that would allow high-compression piston aircraft to use unleaded fuel and improve engine performance at the same time.
The PRISM system is designed to continuously monitor and control cylinder pressure and combustion timing for optimal efficiency. Company officials say the PRISM system would replace both magnetos on a standard aircraft engine with an equally reliable, redundant system. PRISM is designed to give pilots a steady stream of information about the amount of power their engine is producing as well as internal temperatures and pressures. It senses changing temperatures and pressures and automatically adjusts spark plug timing for peak performance.
Other aviation firms have explored variable timing and electronic engine controls for aircraft, but GAMI appears closest to gaining FAA certification of a product designed to allow the use of unleaded fuels in turbocharged, high-compression aircraft engines.
The U.S. Air Force and commercial airlines including Air New Zealand, Continental, Japan Air Lines, and Virgin Atlantic have performed high-profile test flights using bio-fuels made from algae, coconut oil, and other products—but for different reasons. The U.S. Air Force uses far more jet fuel than any other military service branch and wants to become less dependent on foreign sources of oil. USAF officials have said they plan to approve a 50/50 mix of petroleum and synthetic fuel for its jet aircraft fleet. The Defense Advanced Research Projects Agency is working on similar programs to find a bio-fuel alternative to JP-8 jet fuel.
Airlines are looking to bio-fuels to reduce costs, increase supply, and reduce carbon emissions. Virgin Atlantic flew a partially bio-fuel powered Boeing 747-400 on a test flight from London to Amsterdam this year. The fuel, produced from coconut oil and other sources, was designed to dramatically lower carbon dioxide emissions.
Turbine engines are less finicky about fuels than piston engines, but turbines—and the fuel they use—must operate at extreme temperatures. And there is promise that current research may yield new fuels and new tools for current GA engines, which will power GA aircraft into the future.
"Judge a person by their questions rather than their answers."
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 03:29 PM
Fuel Economy related papers tasdrouille General Efficiency Discussion 31 01-18-2011 11:48 AM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 10:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 06:31 PM
