Old 08-20-2010, 12:09 AM   #1 (permalink)
Zerohour's Avatar
Pooparu - '01 Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '011 Cooper
90 day: 36.4 mpg (US)
People Power - '86 Not Slim
90 day: 5.45 mpg (US)
Interesting Bit of Information
I haven't read anything about this here on Ecomodder, but I was doing some searching on ABS plastic and stumbled across this idea:
Take bits of ABS plastic, add acetone in an air tight and acetone safe container. Let set for few hours to days. You'll end up with an ABS putty. Stinks like high hell but I played around with this and it works!
The site I found it on had someone building a custom gauge pod into the existing dashboard of his car. He molded a custom bezel into the existing black trim ring around his factory gauges.
Was a cool idea, and the stuff is sandable afterwards. That means so of the more artistic ecomodders can mold or fill in those rough edges on those mods!
There was also reference to use MEK (fiberglass hardener I do believe) to achieve the same result. Either method yields a pretty unique product!
Old 08-20-2010, 12:49 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
They used to warn us about not handling the MEK unless necessary, FYI.
Old 08-20-2010, 01:14 AM   #3 (permalink)
Zerohour's Avatar
Mini - '011 Cooper
Yeah MEK is nasty chemically. I've gone to charcoal masks, face shields, and tyvex suits for fiberglassing and sanding.
Thats why I used Acetone. Still not healthy, but a little better MEK. This stuff really wouldn't be any worse than using acetone or even paint thinner normally, just need gloves, a mask, and goggles.
Old 08-20-2010, 07:25 AM   #4 (permalink)
Wiki Writer
bugler - '91 626
90 day: 35.89 mpg (US)
good find zerohour.
I found a while ago that this concept also works with polystyrene (i assume it isn't the same as ABS plastic). There are a few instructables about forming your own plastics by "melting" down polystyrene with acetone letting it dry out then you have a hard plastic thing in whatever shape you formed it into.
I tried this out, it works ok for small things but i wanted to make plastic sheets and the sheet deformed somewhat.
I also tried melting down polystyrene (bad fumes) but it worked, melts down to a workable goo and can be put into forms and will make a sheet of hardend plastic however the plastic that is made is not at all flexible. It also destroys your fry pans . Also need a lot of polystyrene do make anything of significant volume since polystyrene is mostly air and when melting it down all the air comes out.
Old 08-20-2010, 09:24 AM   #5 (permalink)
kgwedi's Avatar
Metro - '00 Metro
90 day: 55.62 mpg (US)
RV - '97 Leprauchan 29 foot
90 day: 9.26 mpg (US)
We used to do the same sort of thing with plexiglass (acrylic) and used the goo to repair aircraft windows. Also if you make it thin enough it wicks into cracks.
Old 08-20-2010, 09:46 AM   #6 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...ala' DIY windshield "repair"!?!?!
Old 08-20-2010, 05:09 PM   #7 (permalink)
Mek
ditto on the MEK warnings.If you like hemlock,puffer fish and ZYKLON-B you'll love MEK!
Really,be careful!!!!!!!!!!!!!!!!!!!!
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 46 03-15-2012 07:21 PM
Incorrect Information re: Tire Pressure in Efficiency Mods eco30BMW Forum News & Feedback 129 01-16-2012 03:38 PM
Aero Information Souce: university courses websites mrk Aerodynamics 0 10-29-2009 02:58 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 11:23 AM
