Old 06-28-2009, 02:32 PM   #1 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
Interesting Gauge
Has anyone seen this?
Aeroforce Technology Inc | Products - Interceptor
A lot of the supercharged guys on the Bonneville forum I go to use this gauge. I noticed it has an instant and average MPG function as well. It is a bit pricey but it seems to offer a more functions than the "ScanGauge" everyone is using.
They have this "sample list" posted on their site. I have highlighted a few things of possible interst:
RPM
MPH
Intake Air Temperature (post Intercooler)
Ambient Air Temperature (pre Intercooler)
Engine Coolant Temperature
Exhaust Gas Temperature (PCM Calculated)
Transmission Temp. (auto trans)
Manifold Pressure (vacuum/boost) displayed in PSI
Fuel Temperature
Battery Voltage
Battery Temp
Injector Pulse Width in msec.
Injector Duty Cycle (%)
Air Flow Rate into engine
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Fuel Status (open/closed loop)
Wastegate Solenoid Duty Cycle (%)
Knock Retard
Knock Sensor Raw Voltage
Throttle Position Percentage
Throttle Position Sensor Raw Volts
Calculated Net Horsepower
Engine Load
Transmission Slip
Current Transmission Gear
Torque Delivered to Transmission
Torque Converter lockup status
Brake pressure
Brake Booster Travel
Steering Angle
Non-driven Wheel Speed
Lateral G's
Yaw
Fuel economy (instantaneous and average)
P-ratio - pressure ratio MAP/Barometer
2 user configurable analog inputs**
** 0-5v inputs can be configured to read the outputs from MAP sensors, Air/Fuel ratio kits, pressure or temperature sensors, etc. Raw voltage can be displayed or a conversion can be entered to read proper units.
Users will find that ability to log RPM vs other parameters at high speed such as ignition advance, boost, or knock retard invaluable with regards to tuning.
1996 Pontiac Bonneville SE 3.8L V6
Old 06-28-2009, 04:59 PM   #2 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Looks like a more expensive SGII... less nerdy too.
Old 06-28-2009, 06:22 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
QuickLTD -
Looks cool. Does not *appear* to be as generalized as the SG :
It appears to be CAN-only.
CarloSW2
American Solar Energy Society
Old 06-28-2009, 06:30 PM   #4 (permalink)
QuickLTD's Avatar
It works on the brands listed in the USA too. Yeah I noticed the more limited model range than the SGII. I wonder if it is due to the specialized content it has. I wonder if they think the return on investment would not be worth it for impot models.
Old 06-28-2009, 06:44 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
QuickLTD -
I'll bet they're banking their algorithms and accuracy on the CAN protocol. Things like the Injector Pulse Width and Injector Duty Cycle are not available on standard OBDII, so I am assuming they are CAN-specific.
CarloSW2
Old 06-28-2009, 07:00 PM   #6 (permalink)
QuickLTD's Avatar
http://www.aeroforcetech.com/files/A...f_Feb_2008.pdf They have it broken down by manufacturer and CAN or non-CAN. I looked in their forums and online manuals as well and US is no issue. I am not to schooled in this stuff so I cant say what US OBDII is is isnt capable of but according to them its a go. Heck, I cant afford it anyway I just thought it might be of interest to someone since buying an SGII and one or two other quality gauges would put you right in the price range for one of there .
Old 06-28-2009, 08:37 PM   #7 (permalink)
Steve - '92 Festiva
The thing about these is that there are "gauge packages" with external sensors, etc... which cost more. The main unit is nice, but there are "others" that go with it. That's where they're really going to get your money, the way I understand it, anyway.
Old 06-28-2009, 08:57 PM   #8 (permalink)
QuickLTD's Avatar
Could be I know it does have add ons. I still like it but I will more than likely get the SGII or the Autometer Ecogauage due to its price point
Old 06-28-2009, 08:59 PM   #9 (permalink)
Steve - '92 Festiva
Which is the biggest "point" for most of us here.
Old 07-18-2009, 06:52 PM   #10 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
EPA mandated use of CAN-OBD-II in 2008, before that each manufacturer used different methodologies, Pulse-Width vs. Pulse Amplituide, etc.
That's why it's only recently that 'universal' gauges have become available...which means legacy stuff isn't going to be supported by the new gauges.
FWIW, I have an AutoMeter 9100 ecometer and find it less than satisfactory because basically only the MPG-average display is usable, the other three display modes are too jumpy and fluctuate too much to be usable.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 07:04 PM
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 03:53 AM
Econometer/Vacuum Gauge Installation Guide Johnny Mullet Instrumentation 76 07-29-2010 08:52 PM
SGII Horsepower gauge & related gauges RobertSmalls Instrumentation 3 03-03-2009 09:20 AM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
