Old 12-03-2011, 05:01 PM   #1 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
Interpreting Tire Tread Wear
The best guide I've seen thus far. The guide is done for big truck / fleet owners, but applies in main to personal vehicles also:
KAL TIRE
Tire Wear Conditions
Diagnose Tire Wear
A $5 MILTON Tread Depth Gauge is adequate to most service.
Use of the gauge is shown in this link.
On my pickup truck (sig) I rotate about every 25-30k miles, and use the gauge to take [16] readings per tire annually as rotation is nearly two years apart per service.
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
The Following 2 Users Say Thank You to slowmover For This Useful Post:
Diesel_Dave (12-20-2011), Kodak (12-03-2011)
Old 12-20-2011, 11:37 AM   #2 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Ram 2500 ST Quad Cab 2wd, short bed
90 day: 33.32 mpg (US)
How often do you measure your tread depths?
Diesel Dave
~Life is an optimization problem.~
~Who says that just because your vehicle weighs over 3 tons that you can't get good mileage?~
Old 12-20-2011, 07:42 PM   #3 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...I keep a log-book entry and graph-plot of every tire-depth measurement, just to "see" what the wear pattern(s) are telling me. Also gives me an estimated "life" until wear out depth (3/32"--Lincolns' head).
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 12-22-2011, 02:44 PM   #4 (permalink)
. . On my pickup truck (sig) I rotate about every 25-30k miles, and use the gauge to take [16] readings per tire annually as rotation is nearly two years apart per service.
Agreed. Somewhere around three to four 32" remaining. Also, age. MICHELIN sez seven years for a tire in service, and up to ten for a spare never on the ground.
Fuel Log
Old 12-22-2011, 03:10 PM   #5 (permalink)
Eyeballing the tires is almost daily, or before being driven. Walkaround. Part of keeping the truck washed weekly (mostly) is also the opportunity to look underneath and all around. If there is gravel in the tread I'll pop it out. Same for fueling. I haven't -- until later today -- filled the truck since August. But I have kept an eye on fluid levels, etc, under the hood without needing the excuse to fill up.
I may only run 8-12k miles per year. Same for oil. I'll be below the miles needed for an OCI as a year comes up. Time or miles, whichever comes first. I'm due for all other fluids to be changed (time & miles) but have been unconcerned about it as the use has been so light. Calendar 2012 I'll bring it to par, and get ahead on some items showing wear, but not yet worn out (some bushings and links) and start acquiring some parts to help spread out the wallet pain.
As to tires, I'll need to get a better air pressure gauge this year. I know how far off mine is, but would rather have a top-quality piece. If I need other tires I have also researched what I would use.
Same for a TPMS. I'll be doing a fair amount of towing this coming year, so a TPMS for truck and trailer is needed. I may also need to epoxy paint trailer wheel interiors to forestall leakage, but will also be sure to have tires installed with bead sealer to do keep that slow leak problem away.
If you are asking about the most general rule of thumb for service, I always try to cram them all into either April/May or October/November as the weather is good, and any work I undertake can be checked by a shop when I take it for some forms of service. Folks don't spend much on cars at April 15 or Thanksgiving. A good time to have things done.
I wish to maintain a good relationship with those businesses, and if they see me twice-yearly, they don't forget me when I need that little something extra . . another set of eyeballs looking out for the vehicle. So inspections, registrations, minor services are all combined where possible.
Tire life, brake life, checks for fluid leaks are all part of ECONOMY where, for me, FE is in third place for importance after longevity and reliability. 100k miles plus on tires and brakes thus far with this truck (and getting longer, although I may not push it as far as possible), and excellent FE is all part of a package.
Fuel Log
