Old 10-26-2010, 10:47 PM   #1 (permalink)
RSX2fast4mpg - '02 RSX Type S
90 day: 37.22 mpg (US)
bubbatrucker - '98 K1500
90 day: 18.1 mpg (US)
Interupting my Crankshaft position sensor didn't kill it
So a couple weeks ago I spent $10 for 3 days of access to the Honda/Acura Tech manual website so I could print off the wiring diagrams for the Crankshaft Position Sensor under the dash. It took me a while to get around to it, but tonight I finally got around to wiring in my normally closed momentary open switch and it doesn't work. Or it does interrupt the signal, but the computer overrides it or something.
What happens is when I push the switch it almost stalls, then recovers. If it push it again, it does the same thing unless I push and hold it, in which case it almost stalls, but recovers and then if I push it again, it doesn't even hesitate. Not sure what is going on, but it's not working as a kill switch like it should. Any thoughts?
My only thought is that it uses several signals to determine a stall and if the Camshaft sensors are still providing a signal, it must override the crankshaft sensor. Just a guess.
Old 10-26-2010, 11:41 PM   #2 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
interrupt positive supply to the injectors
do not use a switch directly
use a 5 pin Bosch relay
pin 30 will be positive in before the Bosch relay headed toward injectors from Fuse block or PGM FI relay
pin 87a will be the actual connection from the relay to the injectors positive supply
pin 85 will connect to a momentary contact switch in your car , the other end of the switch to good ground
pin 86 will connect to pin 30
pin 87 is blank or positive to a LED or bulb that shows when you have fuel cut off
Old 10-27-2010, 01:36 AM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
That's probably true. Have you tried unplugging both the crankshaft and the camshaft sensors at the same time? Does the engine start with the crankshaft sensor unplugged? Does pulling only the camshaft sensor kill the engine? In modern engines the ECU syncronises those two sensors at startup, so one can take over if the over fails. In my case the engine doesn't start without a signal from the camshaft sensor, but will work without a hiccup if I unplug it once the engine is turning. Pulling the crankshaft sensor does kill my engine, however.
Piwoslaw's Peugeot 307sw modding thread
Old 10-27-2010, 09:03 AM   #4 (permalink)
The problem with crank/cam sensors is its used for ignition firing and timing and you want spark to always work.
Plus its got to make the ECU throw codes and possible limp mode ,you don't want that .
As mwebb mentions ,the right way is interrupt injectors 12v power side .
Old 10-27-2010, 09:40 AM   #5 (permalink)
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 40.5 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 24.98 mpg (US)
I originally tried interrupting the cam and crank position sensors on my car, but they did not kill the engine either. Then I tried interrupting the ignition circuit, and that killed it, but it had unburnt fuel left over and on restart, it caused a SES light due to wacked out O2 sensor readings when the fuel hit the CAT. You could actually hear the rumble in the exhaust of the burning fuel. Finally I switched the common 12v supply to the injectors, and have been working (killing) great for over 2 years.
moorecomp
Mancelona, MI
Old 10-27-2010, 09:53 AM   #6 (permalink)
Sounds like I'll have to change my point of attack to the fuel injections system. I sure hope that was one of the schematics I downloaded. Ten bucks for three days of access to the manual is rediculous... especially twice.
Old 10-27-2010, 10:00 AM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I think ideally you want both ignition and fuel to shut off. This is what happens when you key off too. Leaving one running without the other creates other issues.
My tbi metro stumbled on if I only killed fuel. There was a lead from the distributor (camshaft sensor) that would cleanly kill ignition and fuel and not throw codes when that circuit was opened (with a nc microswitch on the shifter)
even my 97 saturn mpfi would stumble on and accidentally relight occasionally if only killing fuel. Here putting the nc microswitch in series with the crankshaft sensor worked perfectly, w/no codes.
My tdi golf needs the solenoid on the pump to be interrupted with a more substantial switch.
I think we need a database ( a page in the wiki) of car models and proven effective kill switch approaches. Because if you only have to interrupt a signal level circuit, that is as trivial to do as it gets, whereas if you need to interrupt inductive loads (coil & injectors) then you might have to add a relay or two if you want nice tactile push button control over it.
Old 10-27-2010, 02:34 PM   #8 (permalink)
aero guerrilla
Piwoslaw's Avatar
Diesel
I second this
There should also be a section for known issues for each kill method. For example, doing this-and-this works, but throws code number #...
Old 10-27-2010, 02:38 PM   #9 (permalink)
It depends what you want , if you still have engine turning with this kill switch you definitely want fuel injectors off and spark on . If you want a dead kill then just kill power to whole ECU with the PGM-FI power relay .
Which is basically same thing as turning key off .
On honda/Acura it will kill power to the injectors , fuel pump and ECU , just need wiring diagram .
Chrysler Expected To Kill Models, Bring Italian Vehicles Ashore Jammer The Lounge 17 06-26-2010 07:29 PM
crankshaft position sensor oil drip TheSilverBullet Off-Topic Tech 5 11-12-2009 12:21 AM
