Old 07-06-2009, 11:46 PM   #61 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Frontal area issues should be fixed.
Old 07-06-2009, 11:55 PM   #62 (permalink)
Just some little blurbs (btw it looks great so far). Possibly sorting the cars being viewed by maybe mpg,fuel type etc. might be a nice idea.
Old 07-08-2009, 10:59 PM   #63 (permalink)
Dartmouth 2010
SVOboy's Avatar
Okay, you all should be able to upload photos up to 4megs now. The changes aren't complete, but enough is done to allow for the larger images as of right now. So go crazy.
And let me know if it is broken.
Old 07-09-2009, 08:58 AM   #64 (permalink)
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
I think it's broken
When I try to make a new album, and add an image:
Warning: require(SimpleImage.php) [function.require]: failed to open stream: No such file or directory in /home/greencaralbum/public_html/addphotoalbum.php on line 90
Fatal error: require() [function.require]: Failed opening required 'SimpleImage.php' (include_path='.:/usr/share/php:/usr/share/pear') in /home/greencaralbum/public_html/addphotoalbum.php on line 90
Old 07-09-2009, 10:30 AM   #65 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
The ecomods field keeps cutting off my text when I edit it.
You also need a vehicle class for hybrids.
Old 07-09-2009, 10:49 AM   #66 (permalink)
Dartmouth 2010
SVOboy's Avatar
Crap crap! I will try to fix up some of those things right now. I also have a few more updates I will detail as they go live. Sorry for having so much trouble with the images
Old 07-09-2009, 10:53 AM   #67 (permalink)
Dartmouth 2010
SVOboy's Avatar
Okay, hopefully the image uploading works now...lemme know if otherwise.
Old 07-09-2009, 10:58 AM   #68 (permalink)
Dartmouth 2010
SVOboy's Avatar
Also, two users had orphaned cars, fixed that.
Old 07-09-2009, 11:37 AM   #69 (permalink)
Dartmouth 2010
SVOboy's Avatar
Added a hybrid option to the add garage bit. Also, added rankings to the video section.
Also, think I made the ecomods section longer, you can confirm or deny that for me
Old 07-09-2009, 11:47 AM   #70 (permalink)
Dartmouth 2010
SVOboy's Avatar
Implemented most of the final phases of the new image handling system, hopefully all the images should be intact, if you see anything that looks dead let me know.
