Old 04-06-2009, 06:00 PM   #1 (permalink)
Ernie Rogers
Introducing myself
I am a retired engineer /physicist. I fill my time these days by working on ideas that I think might have some practical value. My strengths are in understanding the science behind things and applying math to problems.
Six years ago, about, I decided to work on some ideas for improving automotive fuel economy. I bought a 2003 Beetle TDI diesel for my "test bed." Frankly, I haven't accomplished nearly as much as I would have liked--which means I have a ton of things yet to try. To start off, I made some small adjustments to the Beetle to improve its mileage.
1) I designed a drag reducer for my car. You can see pictures at www.ernsblog.com and at Welcome to www.max-mpg.com Basically, it's a large "wing" on the back to correct the downflow on the backside of the beatle. My drag coefficient is thought to be about Cd = 0.31. The result is an increase of 3 mpg, roughly independent of speed.
2) Tire diameter was increased by 3/4-inch, going from 205/55-16 to 205/60-16. I also raised tire pressure, using 40 to 44 psi depending on conditions and how serious my mileage goal is.
3) I tested a wide range of motor oils and found that some synthetic oils do improve mileage by quite a lot. Bottom line: lowest factory-approved viscosity gives best mileage.
4) I add lubricity enhancers to my diesel fuel: bout 3% biodiesel, and 1/4-bottle of Power Service (silver bottle) to a tank of fuel. I think there is a modest improvement in mileage from this, and a definite extending of engine life. In highway driving, I think my engine is about 35% efficient. (This is based largely on theoretical calculations.)
From the factory, my car would get about 49 mpg at 60 mph. I now get 65 mpg at 60 mph, driving here at 5000 ft elevation with good summer fuel.
My special interests are tire and wheel design and development of a more efficient engine. I am also involved in aerodynamics, having worked in that field before.
I have been working on the theoretical side of engine efficiency for about five years. I think I know how to build a clean-burning engine that is 60% efficient; a patent was filed in December. I hope to find a source of funding to build the engine and try it out.
As for tires, I am still working on ideas here. Some rules I believe to be true--
1) Soft rubber makes more efficient tires
2) Big wheels with low-profile tires are really bad for fuel economy
3) Narrow, large-diameter tires are best
4) The second number on the tire (profile) should be 60 or higher
5) High tire pressure improves fuel economy AND tire life
6) Pavement matters. Smooth (or lightly grooved) concrete can raise mileage by as much as 10% over smooth asphalt, 15% for rough asphalt.
By the way, larger-diameter tires allow your engine to run at lower RPM where it's more efficient, but I think most of you already knew that. Be careful to correct all data for the change in tire diameter. Watch your speed.
My best mileage ever on one tankful was obtained in a friendly competition within the TDI Club. ( Fred's TDI Page. TDIClub.com. VW TDI Enthusiast Community ) I filled my tank at Park City, Utah and headed east on I-80, driving about 55 mph. I reached Davenport, Iowa, before getting fuel-- a distance of 1,209 miles on 15.5 gallons of biodiesel blend.
When people ask how to get better mileage, my standard answer is, "drive slower and keep your foot off the pedals as much as possible."
Ernie Rogers
Old 04-06-2009, 06:07 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Welcome to the site Ernie. Glad to have you here. I've been to your maxmpg site more than a couple times. You've got good stuff there. Care to share your future plans for the Beetle?
Old 04-06-2009, 06:27 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
Ernie -
Welcome to EM! You're work has been read and cited a lot on this site.
CarloSW2
American Solar Energy Society
Old 04-06-2009, 06:37 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Hey Ernie, glad to finally see you around this neck of the woods,
Old 04-06-2009, 06:37 PM   #5 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Hi Ernie -
Welcome to EcoModder. Your Beetle wing has been mentioned in discussions here several times, most recently here: Old school original VW Beetle aeromods: "Herrod Helper" rear spoiler
Looking forward to finding out more about what you're up to these days.
Darin
Old 04-06-2009, 09:00 PM   #6 (permalink)
Mind if I ask what temperature the engine exhaust is, for the theoretical engine?
Old 04-07-2009, 02:59 PM   #7 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Welcome to the forum
Some things to note about tires.
A harder rubber compound makes a more efficient tire. It improves mileage in the same way as higher tire pressure does. Typically tires rated to last the longest have a harder compound. A harder rubber compound won't give you as good of grip as a softer one so you loose traction.
Also an over inflated tire tends to reduce the life of the tire because it causes more pressure and wear on the center of the tread.
Generally the low profile tires have less side wall flex which reduces rolling resistance. Unfortunately going to a larger rim to accommodate a lower profile tire may increase the rotational inertia of the wheel. Which way to go depends on if you do a lot of stop and go driving or if you do a lot of driving at constant speeds for extended periods of time.
Also its important to note if you go to a larger diameter wheel with a larger profile this will make your car handle worse and make it more prone to rolling over.
Changing tire diameter doesn't always help. Some cars have their gear ratios set to optimize the engines maximum efficiency rpm range to the typical speed limits.
In your situation with a diesel, peak efficiency typically occurs at the rpm where peak engine torque is generated.
Old 04-08-2009, 02:43 AM   #8 (permalink)
Ernie Rogers
Hello, and thanks for the welcome. Pardon my bruskness at times, I don't mean to offend, but--
The energy loss in a tire comes from the work it takes to deform the rubber as the tire adjusts to make its contact patch. A hard rubber takes more work to deform it so it loses more energy, and is less efficient. A corollary is that a well-worn tire is more efficient than a new tire--less rubber to bend.
By the same logic, you should conclude that a low-profile tire is less efficient because more deformation in the wall is required to form the contact patch. This is verified by experiments, and common experience by drivers.
High tire pressure improves efficiency because the contact patch is proportionately smaller, and deformation is less.
About high pressure and tire life-- it's my experience that a good tire with a solid radial belt won't wear unevenly in the middle. Many police and highway patrol cars have tire pressures above 50 psi (for improved safety) with no such wear problems.
About wheel moment of inertia-- that's mostly an old myth too. Wheels and tires have double the effect on car total inertia because they both spin and move linearly. If you increase the weight of wheels and tires by 15 lb each, the total effect on the car is the same as adding 120 pounds in the trunk, or a small mother-in-law in the back seat. Smile, you will get by just fine.
Your comment near the bottom, about larger tires not always working for some cars, is probably true, especially with some automatics. For my car, it's speed for best mileage appears to be somewhere near 50 mph in fifth gear. And, I think you should only make small changes in tire diameter, less than two inches unless somebody has already tried it.
Sorry about the lecture.
Ernie Rogers
Old 04-08-2009, 03:23 AM   #9 (permalink)
Ernie Rogers
Ooops, I'm embarrassed
Ooops, now that I have read all the posts in this thread-- a person can be rude on the internet, thinking that nobody knows who he is--but it seems everybody knows me here. Now, I wish I hadn't been so hard on a couple of guys.
Hey, unchosen, you sound like an automotive engineer, very astute question. Let me look that up for you.
The calculated exhaust temperatures are--
For my Beetle engine......... 900 deg. K at 1.1 atm.
For the new engine........... 580 deg. K at 1.1 atm.
Now, if you wanted to verify engine efficiency, you would need to have the approximate combustion temperature....that's 2,000 deg K for my engine. You could apply a mechanical efficiency factor of 0.85, and the Carnot efficiency formula, to estimate brake efficiency for the "theoretical engine."
Ernie Rogers
Old 04-08-2009, 08:44 AM   #10 (permalink)
That sounds interesting. Must be using something other than standard motor oil as it breaks-apart and or ignites above 773 K. Yeah I am an ME student, but I used to be a ChE senior, why I asked about the temp(thermo and organic).
beetle, fuel economy, wing
Introducing my newest old car Coyote X Introductions 19 11-25-2010 01:00 AM
Introducing EcoRenovator.org! Like EcoModder, but for homes SVOboy Saving@Home 14 09-10-2010 03:42 PM
The new guy here, introducing myself swskeptic Introductions 6 02-12-2009 07:01 PM
Introducing me teguh123 Introductions 0 02-12-2009 07:06 AM
Lurker, now introducing fud2468 Introductions 3 08-22-2008 10:39 PM
