Old 10-02-2008, 12:27 PM   #11 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
That crazy lockdown nonsense is the #1 reason I don't have an iPhone. #2 is because I'm not on AT&T. I'll stick with my Guino (once I receive the parts and build it that is).
If I was going to go through the effort of building that kind of power into an odb interface, I'd just put a PC in my car and be done with it. Cool idea, though, from a "what if" standpoint.
Old 10-05-2008, 11:19 AM   #12 (permalink)
Hi you guys,
there should be given some clearance about iPhone or iPod Touch and OBD-II.
Bluetooth or serial data transfer does not work. WiFi is used however and it has the fastest data transfer available nowadays. Therefore the Rev software makes use of an WiFi OBD-II device which you might see at OBD-2 Homepage the hardware developper for this device. Of course such things are not for free.
Gerhard
Old 10-05-2008, 11:30 AM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I think we've figured that much out, problem is the cost of going that route vs a building a dedicated display device is very disproportionate. There are plenty of handheld devices that DO allow serial port access too.
I wonder what the iphone does with it's bluetooth/serial port though. maybe there is some built in synch-up routine that you can use to get data to a file on an iphone or something?
Old 10-05-2008, 11:46 AM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
It seems like it could be possible to utilize one of those inexpensive usb adapters as well.
D-Link WUA-1340 USB 2.0 Wireless Adapter - 54Mbps, 802.11g (Recertified) RB-WUA-1340 at TigerDirect.com
Old 10-05-2008, 12:16 PM   #15 (permalink)
Any other way like Bluetooth or USB is not as fast as a direct transfer via WiFi. Any other adapter on the data way will become a bottleneck to slow down everything. Keep in mind also there are several Bluetooth services. The SPP service is not supported by an iPhone. For any other handheld you may use such a cheap solution and you must be satisfied by the poor performance also. Better performance has its price however.
Old 10-05-2008, 01:04 PM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
I don't see the need for a wide bandwith for obd, we are not talking about videos here, just some sensor bytes. Those rad folks said they were addressing the price issue soon, so maybe they have come up with something. Direct wifi is definately overkill for this application and direct usb should blow its doors off performance wise.
And there's plenty of other devices that can interface with the real world without making you spend hundreds just on the interface. That is the stupid part here. Rad says they may have a low cost solution though, so stay tuned I recon.
Old 10-05-2008, 01:26 PM   #17 (permalink)
Obviously you have not seen this application in real live working. So you don't know the difference compared to other devices. Even some vehicle manufactures switches to wifi now because they cannot handle the data flow in modern vehicles with plenty of ECUs otherwise.
Old 10-05-2008, 02:06 PM   #18 (permalink)
dcb
needs more cowbell
dcb's Avatar
Sorry, I gotta call BS on that.
Old 10-05-2008, 02:13 PM   #19 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I agree
Old 10-05-2008, 02:15 PM   #20 (permalink)
Who or what is BS?
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
