Old 06-24-2009, 05:08 PM   #151 (permalink)
'01 Jeep Cherokee - '01 Cherokee
90 day: 17.62 mpg (US)
Great thread!
I have a 2001 stock Cherokee. I live in a dormitory so I don't have access to a garage to screw around very much. I'll probably remove the roof rack since it is a simple start. Unfortunately my average speed is ~20mph so any aerodynamic mods will result in negligible gains.
I'll definitely keep an eye on this thread.
Old 06-27-2009, 09:34 PM   #152 (permalink)
Found some Cherokee tuft testing that a guy did to figure out where to add hood vents. He found that pressure is pretty low at the front of the hood... so you could potentially reduce drag by putting vents there
Bonnet
Old 06-27-2009, 10:24 PM   #153 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 15.69 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 39.56 mpg (US)
Originally Posted by oisiaa View Post
Great thread!
Watch those tire pressures. A very simple thing that can make a big difference, no matter what the speed.
Bonnet
Tempting, but I'm not too prone to cutting holes in my car.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 06-29-2009, 04:12 AM   #154 (permalink)
Do you have a plastic/rubber splash guard? I didn't think there was one available for the XJ but apparently there is. Found out because I was searching for info on front hitches conflicting with skid plates
Front hitch or tow hooks question - [Archive] - ILOVEJEEPS.com Forums
the splash guard will help to reduce the amount of spalsh into/onto the alternator (and other under hood, but the alt seems to benefit most) ... you can live fine without it, though you may notice:
slightly decreased high-speed cooling (less negative pressure behind the radiator and more of a propencity for the high-pressure area in front of the front diff to reduce air flow
more of the classic "mud/brush" conflict with the alternator (the alt hates to get wet or fouled with mud - it'll float a brush pretty easily - just carry some clear water to rinse-off the back )
Decreased heater output on really cold days (the flappy thing actually diverts really cold air off of the oil pan, running with and without it on one of my '87s made a huge difference in cab comfort when outside was below roughly 10*F)
Decreased water fording depth (again the pressure things - slow-speed fording depth will be reduced since you'll be less able to build and hold a good bow-wave
Really though -- all of those things are really minor, and about the only thing you may see is that your alternator will be a bit more prone to fouling and maybe a little drop in fuel economy (will a factory or other front skid plate fit on with that hitch mount? that'd clear all the stuff up.)
Old 06-29-2009, 04:47 AM   #155 (permalink)
I do, but it's starting to fall apart in a few places. The new front skid plate pretty much takes it's place keeping water/mud off the front engine compartment.
Old 06-29-2009, 04:52 AM   #156 (permalink)
You got a skid plate? The OEM one?
I'm looking for an OEM but can't find them for sale anywhere. The aftermarket ones are probably heavy, because they're thick plate instead of thin sheet with ridges for strength
Old 06-29-2009, 01:11 PM   #157 (permalink)
Yes and no. It's part of my under body tray. My design splits it up in to different sections similar to what the off road Jeeps have. Which I guess is why I call it a skid plate. By no means should you put the weight of the Jeep on these. They are galvanized steel used for home heating air ducts. So each panel weighs about 3 pounds. Check back a few pages on my post to see what I'm talking about.
Old 06-29-2009, 10:25 PM   #158 (permalink)
Ah OK, I missed those posts. I didn't realize you had the belly pans
Old 06-30-2009, 07:47 PM   #159 (permalink)
I have another idea-- cover the headlamp buckets with clear plastic. I realized while half asleep in bed, that this could have a HUGE effect, because not only would the flow be much smoother, but it would then stay attached as it hits the radiused corners of the front end.
I've found that the unpainted black buckets go for about $20 on eBay, so I'll probably try this at some point. Don't want to drill into my color matched painted stock ones.
Ordered a front skid too... Found them for only $52+$9 shipping
In case anyone wants these, part # 82202851 at http://www.moparpartsamerica.com/
Old 06-30-2009, 11:31 PM   #160 (permalink)
Check the laws concerning headlights in your state. Some have rules about not covering the headlights.
I have been tempted to at least seal the gap around the headlights. Having the pressure zone in the front would be better then the air headed in the messy engine compartment.
low pressure kills mpg's
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/jeep-cherokee-aeromods-2614.html
Posted By For Type Date
Simple Tips for Saving Fuel During Cold-Weather Driving - Digg This thread Refback 11-11-2011 02:54 PM
Jeep Cherokee Front Bumper - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 02-21-2010 06:01 PM
Aeromods V1.0 trikkonceptz Aerodynamics 50 10-14-2011 12:30 PM
Glides like a Brick Wall (Jeep Cherokee, GMC Pick-up) DonEaston Aerodynamics 22 10-26-2008 05:17 PM
jeep aero mod ideas johnpr Aerodynamics 22 08-27-2008 08:45 PM
mpg + jeep - thinking cap help? tkmd EcoModding Central 6 04-28-2008 10:15 PM
Off-Road Test: '08 Jeep Grand Cherokee (Rally Race) RH77 The Lounge 4 02-25-2008 04:59 PM
