Old 07-01-2009, 01:41 AM   #161 (permalink)
Looks like clear covers are OK in Texas
Texas Department of Public Safety - Inspection/Rejection Criteria
6. All head lamps will be inspected for and rejected if:
n. Lens is other than clear (white).
s. Head lamp is covered by any lens or cover located in front of the head lamp which is any shade or color other than clear.
Of course my headlamps are illegal anyway. I replaced the sealed beams with H4 e-codes.
Old 07-01-2009, 05:27 AM   #162 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 15.69 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 39.56 mpg (US)
Did you have any ideas of how you would mount the clear plastic? I know I've looked at it and unlike the grill it doesn't seems to have any lip at all.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 07-24-2009, 11:41 PM   #163 (permalink)
The headlamp surrounds come off when you remove two screws down at the bottom front. You'd just have to drill holes and run bolts through.
Old 07-26-2009, 02:07 AM   #164 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Neon SE
90 day: 36.28 mpg (US)
S'Crew - '02 F150 Supercrew XLT
90 day: 16.4 mpg (US)
EX - '94 Explorer
90 day: 19.58 mpg (US)
Ranger - '90 Ranger
Last 3: 28.02 mpg (US)
I'm looking for an OEM but can't find them for sale anywhere. The aftermarket ones are probably heavy, because they're thick plate instead of thin sheet with ridges for strength
A recent trip through the local junkyards showed a few have been yanked. I was looking for one for my daughter's XJ. I have the factory one for my ZJ that is plenty stout. But I broke a mounting bolt and took the plate off due it vibrating at low RPMs.
When it comes to Heroes, RENEGADES are mine!
Old 07-31-2009, 08:14 AM   #165 (permalink)
Has anyone tried a header and a cat back exhaust? i'm curious to see if that will add any efficiency to the 4.0 since the exhaust is pretty restrictive. i have a 99 cherokee with a 4.0 and would like some real world feed back on this mod before i do it.
Old 08-01-2009, 02:15 AM   #166 (permalink)
I don't know about exhaust but some people say they get better gas mileage with a snorkel.... Not sure if that's really possible since you're giving the engine cooler air
Old 08-01-2009, 02:36 AM   #167 (permalink)
high school
ModelE's Avatar
sabre - '02 LeSabre Custom
90 day: 23.45 mpg (US)
frontier - '04 Frontier XE
90 day: 18.97 mpg (US)
Originally Posted by Nerys View Post
There is a few ways you can start to improve both off road performance AND aerodynamics :-) Skid Plates
Yeah love skid plates anyway the Front skid plate would start up an underpan belly quite nicely with some added bonuses. Its metal good protection of your belts and namely the alternator which is prone to failure from water and mudd entering it directly. The skid plate stops the majority of this (have not killed an alt since installing it went through 4 of them prior to that. :-)
yeah but skid plates add a bit of weight, and intense ones can outweigh their benefits.
EDIT: just a disclaimer, ignore this if it's irrelevant.
Old 08-01-2009, 12:00 PM   #168 (permalink)
The stock Jeep skidplates are pretty thin steel, with ribs molded in for rigidity. I think the front one is supposed to weigh 20 lbs or less. The aftermarket ones are usually really heavy 3/16 steel
Old 08-22-2009, 11:32 PM   #169 (permalink)
Here's my first aeromod on the XJ... finally found a front skid plate. Tomorrow I'll be putting on a full width belly skid too, and extending part of it to protect the muffler and cat. Then it will be very easy to add more bellypan.
I wish I could have gotten a good Scangauge comparison between the original air dam and the skid sans dam, but I messed up my calibration settings. It's a long way to a flat highway too.
Old 08-23-2009, 03:38 AM   #170 (permalink)
That sucker looks nice Looks about the same angle/size as mine, maybe just a tiny bit higher. You should notice a difference in coasting time with that thing. The key is to re-training yourself on when to let off the gas and let it coast to the light/stop sign.
low pressure kills mpg's
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/jeep-cherokee-aeromods-2614.html
Posted By For Type Date
Simple Tips for Saving Fuel During Cold-Weather Driving - Digg This thread Refback 11-11-2011 02:54 PM
Jeep Cherokee Front Bumper - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 02-21-2010 06:01 PM
Aeromods V1.0 trikkonceptz Aerodynamics 50 10-14-2011 12:30 PM
Glides like a Brick Wall (Jeep Cherokee, GMC Pick-up) DonEaston Aerodynamics 22 10-26-2008 05:17 PM
jeep aero mod ideas johnpr Aerodynamics 22 08-27-2008 08:45 PM
mpg + jeep - thinking cap help? tkmd EcoModding Central 6 04-28-2008 10:15 PM
Off-Road Test: '08 Jeep Grand Cherokee (Rally Race) RH77 The Lounge 4 02-25-2008 04:59 PM
