Old 04-29-2008, 10:55 AM   #1 (permalink)
awillard69's Avatar
Dakota - '00 Dakota Club Cab, Sport
90 day: 18.57 mpg (US)
Jeep - '01 Wrangler TJ Sport
90 day: 18.46 mpg (US)
Smile Jeep grill block
I took my inspiration from 2005 Civic Upper Grill Block and picked up some pipe insulation from the home center.
The gaps in the Wrangler grill are 2 inches wide, so I got the largest insulation I could get. I got the firmer stuff, not the squishy stuff.
I cut it slightly longer than the opening and wedged it in. It seems to hold in there OK, standing still at least. But it was clear that it wouldn't stay, so I notched, actually just a slit, in the top and bottom and used that to hold to the upper and lower ends in place.
A few test runs yield them pretty stable, however in every attempt at speed one would get pushed into the space behind the grill. There must be just enough pressure build up ahead of them and once one gives, the rest are spared.
So, now I'm down to finding a way to keep them in. Short of hot melt glue tacks, I need to find a way to keep them from pushing through. I was thinking about lacing them together with monofilament line, but that won't do on the ends. Toothpicks may work, but may be unsightly, and won't be a long term solution.
I don't have good numbers with the SGII yet, check out the trip logs for any details. I've had to reinstall my spare and am getting ready for a road trip - it's a Jeep thing...
Anyway, here are a couple of pics to show my progress.
Old 04-29-2008, 11:15 AM   #2 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Perhaps you just need to leave one out and go from there.
Is there any one particular piece that seems to be the most prevalent at coming through?
That would be the one to leave out, common sense would say that is your point of stagnation.
If it is always a different one then just leave out the one in the middle.
Just a thought.
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 04-29-2008, 11:22 AM   #3 (permalink)
awillard69's Avatar
No, it's not been the same one twice. It's pretty much just a friction fit, and once the radiator warms up, it may cause the material to soften. Leading me to some form of attachment, hot melt, monofilament, etc.
But, I was considering leaving out the center one, for aesthetic reasons.
I don't have enough data to indicate whether leaving one out is relevant or not; nor do I know how much impact it will have overall - can I get .5+ MPG out of it?
Old 04-29-2008, 09:51 PM   #4 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
well, if they were more streamlined with the front, so that there's more air being directed around the Jeep instead of around the foam, you might yield better results. I gained actually about 1-3% out of it, which for me is about 1-3mpg's depending on the weather and wind conditions. Mine are clear plastic though, and I don't know where it came from, I just got it from my shop teacher, who had some extra laying around from our solar boxes.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 04-30-2008, 08:40 AM   #5 (permalink)
awillard69's Avatar
I know I should use something else, but I was trying to prove the point first, cheaply. I intend to fab up some kind of flat block. But the foam was cheap and easy to work with.
I ended up skewering it with some bamboo skewers colored with a Sharpie. They held in great this morning.
I'm attending the Jamboree in Kentucky this weekend and wanted it in place for the trip down. $4 gas is a strong motivator!
Old 04-30-2008, 02:12 PM   #6 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
Good luck awillard. I've always wondered that going with a grille block on the TJs would actually make it worse cause you have another flat surface moving through the air. With the grille open atleast there is a path for air to flow. Post up any results you get
Have fun at the Jamboree!
Old 04-30-2008, 02:26 PM   #7 (permalink)
awillard69's Avatar
Yes, I wish I had more time to perform some test runs. I'd like to know if I'm wasting my time (and $) before I do 500 miles! The data for my daily commute don't reflect anything conclusive - crap traffic and poor light timing compromise any days' readings.
The fuel logs will reflect total highway effectiveness. Check back next week.
Old 04-30-2008, 08:54 PM   #8 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
If you have room, put a 2 strips of wood in the back horizontally and screw them in from the front. You might be able to secure the wood strips to the grill from the back.
Old 04-30-2008, 09:30 PM   #9 (permalink)
remember that the Radiator is right behind it, and it IS another flat surface moving through the air. without the foam, you have turbulent air hitting the grille openings, then it's hitting and going through the wall-like radiator, which gets sucked by a fan (if there's a mechanical one) and pushed into the motor, which gets jumbled around. It's basically gonna be the same, but maybe direct more air around the jeep. without smoke or windtunnel testing I wouldn't know for sure
Old 05-01-2008, 09:14 PM   #10 (permalink)
awillard69's Avatar
I haven't compiled the fuel data yet. I pushed a 20+ MPH headwind for almost 400+ miles - really ate into any savings. While in a protected area on flat road and not other traffic I was getting 22+ instantaneous MPG readings. I cannot attest to the block being the bonus or 60 MPH.
As a note, all 7 blocked shot the water temp to 230 and beyond, so a quick stop and I pulled the center block, then the temp returned to the 208-211 range which is more typical.
Eyeball estimate is about 20 MPG, but won't know until I enter the log data.
OEM Grill Block for 92-95 Civic Owners TomO EcoModding Central 2 10-04-2011 12:31 AM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
Grill Block Poll. Ryland Aerodynamics 18 11-09-2009 12:00 AM
My try at a partial grill block bhazard Aerodynamics 15 04-30-2008 10:09 PM
