Old 09-05-2010, 10:29 AM   #11 (permalink)
44 Dan
44Dan's Avatar
Air flow ribbons tied to the vents showed positive air flow out from engine bay at various speeds including highway speeds. My fault not mentioning that earlier. We were not worried or thought about negative pressure build up but rather wanted to see how well the air flowed (one guy did anyway) so we tied small ribbon strips to the vent openings and the engine bay pressure was extreme from where we put our vents which were more central located on the hood. Wish I could find an old photo but I can't find one. We see a lot of Jeeps with this less than $5 mod in Arizona, especially the hotter areas.
Hope This Helps
2007 Prius 40mpg's
2010 Harley Davidson 38mpg's
Tire size and FE with a Jeep zjrog Off-Topic Tech 22 01-24-2011 10:32 PM
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 12:39 AM
Honda element, vw beetle, jeep wrangler... hans2vt Introductions 9 05-08-2009 04:05 PM
Off-Road Test: '08 Jeep Grand Cherokee (Rally Race) RH77 The Lounge 4 02-25-2008 03:59 PM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
