Old 04-23-2009, 10:19 AM   #21 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
My understanding is, the back end of a car potentially has more effect on the overall c/d than the front (unless you go drastic in front, with a long slope like basjoos). We don't have a really good view of the back but I can see the final cross sectional area is still pretty big. That's what determines the overall size of the wake, correct?
As for the rest - if they really want to drop the c/d, the car needs a full belly pan. But they don't get 'cool' or bling points for that so might not do it. Would be a shame to not treat the underside though; it should be cheap to build and no 'styling' penalty for using an optimum design.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 04-23-2009, 10:35 AM   #22 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
The new Prius does in fact have smooth belly panels. GM should definitely take notice.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 04-23-2009, 10:36 AM   #23 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Originally Posted by Southcross View Post
lawls... I bet the mirror design shaves 3pts off the cD
Actually, some people furiously argued that the mirrors were not causing drag at all. So they must have been shaving points to compensate for their area...
Not that I believe it's the case though...
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-23-2009, 10:39 AM   #24 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Correct, assuming attached flow to the cut-off. It's not significantly different than the Prius rear end.
If they have in fact managed to beat the Prius 0.25 figure, you can be sure they have paid attention to smoothing the underside. The bottom of the Volt's battery pack itself will be flat, and it occupies a significant amount of the underside real estate.
AutoSpeed Article: Low Drag Car Aerodynamics TestDrive Aerodynamics 3 03-10-2009 10:50 AM
Article on the History of automobile aerodynamics (through 1989)_ basjoos Aerodynamics 6 05-10-2008 04:37 PM
