Old 05-26-2015, 11:59 PM   #11 (permalink)
Sorry, I should have been more specific. My reference to carb icing was referring to the two carburators with heated screens. How much do those things cost?
Old 05-28-2015, 12:16 AM   #12 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
The EFEs might help reduce carburetor icing. But then again I do believe they are only for start ups. If you have carb icing I would think you'd need either a heat riser system or a heated air cleaner that pulls warm air off the exhaust (or an air-cooled head as in my case). My engine has dual heat risers and a heated air cleaner. But you can do a search on them. Looks like they run $100 USA and up. The non-heated Jet-A-Vator runs about $60 to $90.
Jet-A-Vator
Old 06-01-2015, 02:57 AM   #13 (permalink)
Full sized hybrid.
Any input on whether I should get the 20, 30 or 40% restriction Jet-A-Vator?
Old 06-01-2015, 06:05 AM   #14 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Tin cans, nail, hammer.
Old 06-01-2015, 11:05 AM   #15 (permalink)
Smells like unicorn dung
Restrict the fuel flow by being more gentle with the throttle and you'll also get better mileage.
Old 06-03-2015, 12:58 AM   #16 (permalink)
Full sized hybrid.
Question
Any thoughts as to why all those that I know who've put this thing on their car have noted it improves starting and smooths out any poor running? Is that a sign it does help atomize fuel?
Old 06-03-2015, 03:57 PM   #17 (permalink)
A lot of little holes create more turbulence than one big hole?
I'm reading between the lines here; a 34PICT with a[n exhaust] heated air cleaner? Is that 1302 in your avatar pic the vehicle in question? What color is it? Whose programmable ignition?
If you're not familiar, Hot VW's Mileage Motor series covered the Jet-a-Vator in part 10. It is here.
They reported a 10% improvement in mileage, testing revealed a performance hit they couldn't feel by seat-of-the-pants.
Edit: On a highly tuned dual port 1776 with dual carbs and a Freeway Flyer transaxle. They took it from 28 to 38mpg.
Old 06-03-2015, 04:42 PM   #18 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.01 mpg (US)
In their Mileage Motor series (and I'm surprised I haven't been banned for referencing the article so often), HotVWs Magazine reported a pretty strong increase in fuel economy when the tested a similar device vs. the same engine without it. They also reported certain qualitative effects, which I disregarded.
HVW's testing methods aren't the best but I've seen worse.
[edit]
Hey! Freebeard beat me to it.
Anyway, there it is.
Old 06-03-2015, 04:46 PM   #19 (permalink)
Master Novice
elhigh's Avatar
A performance hit that was nonetheless on an engine that developed over 90hp on the dyno, if I recall - a big step up from stock and, as they reported, a helluva lot of fun to drive. The VW they were testing went from your basic slug to peppy bug while delivering excellent mileage, proof that economical doesn't mean slow.
Old 06-03-2015, 06:17 PM   #20 (permalink)
I'm betting Isaac Zackary reads the whole MM series (if he hasn't), based on his avatar.
I have a stroker 1776 sitting on the bench, built to the original Jon Karcey specs. (It's been on that bench a while) I wanted to link to the original VW Greats article but the trail has gone cold at Southernvolksfolks.com. Long story short, I used big valve heads thinking it would be propane-fueled truck engine, while HVW went with fuel injuction heads for the smaller intake valves. But I did find this: VW Type 1 Mileage Master MPG Engine Combo « VW Parts – Aircooled.Net
