Old 03-30-2011, 03:57 PM   #1 (permalink)
fuel efficient race car - '02 RSX Type S
Last 3: 34.41 mpg (US)
Lil Fit - '07 Fit Sport Auto
90 day: 39.56 mpg (US)
Project EG - '92 Civic CX
90 day: 39.82 mpg (US)
Jumping in, 92 Civic CX with DX swap.
I had been searching for quite sometime for a clean Civic HX or VX to no avail. Most were overpriced, swapped, or otherwise beat to death. I opened my search to the anemic CX as a potential VX or HX engine swap candidate but still nothing out there.
Until last week, when on my day off I decided to check the Raleigh area Craiglist one more time. I had already been denied another HX in Maryland that sold in two days. This beauty popped up and I called the place, told them to hold it, and I would be right there.
I couldn't get there fast enough!!! 104,000 miles, theft recovered CX, with a recent maaco (aka: crappy and oversprayed) paint job. Interior is clean, no tears in the pleather, and nice and black. Just missing a few things like the ash tray and the trim piece around the cd player. I popped the hood and noticed a DX engine inside. A free 30 horsepower upgrade. I'm thinking it has been mated to the stock CX trans which should maintain the good gas mileage because the gearing is dog slow. I will write the trans code down and do more research on it. The tires are matching 09 year as well as the battery. The air intake tube is a CX tube poorly stuck on the larger DX throttle body. Will need to source something better than that. A straight metal tube would be ideal.
Overall, clean and straight.
So far I have removed the lock cylinder and moved the tumblers around to get the key to work in the driver's door. I also added my leftover Integra type R strut bar. Nothing gets rid of rattles and makes a civic feel tighter than that little mod. I've had one on every honda/acura I have owned. Also, aimed the headlights a little better and filled up the tank. At 200 miles at the halfway mark currently. Hoping for 45 mpg but we shall see.
Old 03-30-2011, 04:06 PM   #2 (permalink)
First real mod will be security!!
It only took me 14 years, two EG sedans(one B swapped), an RSX-S, a 90 accord, an 07 Fit, and a 99 integra, to finally get my first EG hatch!!!! Isn't that where us Honda guys are supposed to start?
Old 03-30-2011, 09:09 PM   #3 (permalink)
Just detailed the interior only to find out the floor on the passenger side was soaked and possibly the driver side floor too but not as bad. I think I can hear water swishing about when turning. The rain was intense the past few days. Also leaking from the tail light gaskets as well. Le sigh.
Old 03-30-2011, 09:23 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Leaks always annoyed me a lot with my CRX. They're all easy to fix though.
Did you already swap the DX engine in?
Old 03-30-2011, 09:56 PM   #5 (permalink)
It came with it. Still has the CX header and one wire 02.
Old 03-31-2011, 12:27 PM   #6 (permalink)
Nice little red machine you rarely see a civic with so few miles on it. The CX is a good base line I knew a guy that have an original CX and all he did was lower it and put strut bracing on it and a 5spd stock CX conversion.
2 cars one never gets driven the other is an MPG project already at 5% increase in standard driving economy CAI and Pulstar plus. Thinking weight reduction next year.
Old 03-31-2011, 12:49 PM   #7 (permalink)
Turns out there is a TSB regarding the leak. I need to remove the fenders and apply additional seam sealer at the base. I'll post the TSB pic later.
I couldn't believe the mileage as it's so easy to swap clusters but the pedals, carpet, seats, and trim still look really good.
Old 03-31-2011, 02:42 PM   #8 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
You should be able to get 50mpg out of that without to much trouble once you get it all in order.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 04-01-2011, 02:21 PM   #9 (permalink)
We shall see.
Update : ordered the rear diffuser/cover from the VX model! I was already ordering tail light gaskets and other miscellaneous clips and covers. What's another 40 bucks?
Old 04-02-2011, 09:50 PM   #10 (permalink)
Canary5_0's Avatar
Lola - '95 Mustang GT
Team Ford
90 day: 24.81 mpg (US)
Wall-e - '012 Golf TDI
90 day: 41.11 mpg (US)
Welcome!
"If you do things right, people aren't sure if you've done anything at all."
