Old 04-20-2008, 03:26 PM   #21 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Originally Posted by PaleMelanesian View Post
Accuracy - I've got a year and over 10,000 miles on mine. I've recorded the actual gallons and back-calculated the un-adjusted gallons for each fill. Once I locked in my offset, it's been +- 1% or so for the whole year.
I've had my original SG since mid 2006, about 50,000 miles ago, when I started reading Darin's website, www.metroMPG.com. These SGs are able to be adjusted to match the readings at the pump, it usually takes a few tanks to get it to be within the 1-2% range of accuracy. But, like Ron Popeil says, "Set it and Forget it!" Once you have the percentage fuel consumption changed to match the pump, your Instantaneous and Trip MPGs will be right on the money.
The percent offset settings for the fuel are in the settings>fill up> section of the scan gauge, if my memory serves me correctly. Check out this thread and that should help.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 04-20-2008, 05:52 PM   #22 (permalink)
Little crown - '03 Corolla CE w/ S body kit
90 day: 40.75 mpg (US)
yeh my sgII was way over what my actual was but then i adjusted the fuel consumption and it seems to be more accurate
Old 04-21-2008, 07:28 AM   #23 (permalink)
Funny's Avatar
Easiest way to calibrate it is to get your mileage the old fashioned way (at the pump) and configure it that way with the gallons consumed. I know I had to do that a couple times to get the mileage to be in the ballpark, then the next couple to get it on the money.
American by right
Ecomodder by choice
Old 04-22-2008, 12:45 AM   #24 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
That's for Deceleration Fuel Cutoff - coasting in-gear, some vehicles cut fuel to the injectors. The setting it to adjust the threshold where that is recorded.
How do I adjust mine so its accurate?
manual that came with mine mentions absolutly nothing about it anywhere..
Old 04-22-2008, 10:00 AM   #25 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 72.37 mpg (US)
When you do a fillup, you can adjust the gallons. It'll apply that % adjustment to the fuel flow numbers from then on. You can change it on the fly within the first gallon of the new tank, too.
When I fill up, I record actual gallons and Scangauge gallons, calculated back to remove the offset. In my case it's +8% gas = -8% mpg. I have a running average for the difference, and use that as my default.
Also, the Speed adjustment also affects miles, so you can lock that in to whatever you want.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 04-22-2008, 07:23 PM   #26 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
As reference for those reading this thread.
My Scangauge is never accurate, always reads to much fuel flow on higher flow rates and to low of flow rates at lower flow rates. Basically the Curve is off. Likley a Diesel Only issue . . .
Some suggestions for attempting to nail it down.
1) only change your mileage 1/2 of the way to what it should be, eliminates "bounce"
2) Keep on trying
Of course out of the 5 Vehicles I'm normally in with SGII's only 1 (the golf) has an issue.
6 speed ALH TDI
Old 04-22-2008, 08:03 PM   #27 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
I assume you've selected Diesel as the fuel in one of the sub-menus. IIRC, there's Diesel-1 and Diesel-2 -- have you tried both? If so, is there better accuracy with 1 over the other?
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 04-22-2008, 08:38 PM   #28 (permalink)
6 speed Diesel FTW!
Diesel
Made a new thread to avoid Hijacking this one.
http://forum.ecomodder.com/showthrea...1021#post21021
6 speed ALH TDI
Scangauge II Question (suddenly seeing inflated MPG numbers) awillard69 Instrumentation 7 04-17-2008 01:04 AM
ScanGauge II on eBay (not mine) MetroMPG For Sale 15 02-29-2008 02:44 PM
