Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 07-20-2008, 10:34 AM   #11 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
How are you connecting the batteries? Spot welding them to metal sheet?
Nissan Versa Aeromods
Old 07-20-2008, 12:05 PM   #12 (permalink)
NES Collector
Tom Baker - '03 Echo
90 day: 44.53 mpg (US)
Big Blue - '03 Caravan 2WD
90 day: 20.85 mpg (US)
No I'm soldering them in series. Here is a pic. of some NICD's I got from work that I'm working on to use for trips to/from my parents house.
I've built a wooded bot to put them in.
These boxes will go into my rear baskets.
"Would you like a jelly baby"
Miles Displaced By
Walking = 3.6
Old 07-20-2008, 06:33 PM   #13 (permalink)
NES Collector
Here's a pic of the batt's wired. Not fully charged yet.
Miles Displaced By
Walking = 3.6
Old 07-31-2008, 11:39 AM   #14 (permalink)
Happy Hyper
Jake's 05 Malibu - '05 Malibu
90 day: 31.42 mpg (US)
Send a message via Yahoo to jakemacd
Aren't those little jumper wires going to get really hot, Ecomodder?
Old 07-31-2008, 03:23 PM   #15 (permalink)
Just a suggestion: if you want cheap NiMH batteries, look at auto salvage yards for wrecked hybrids. You can often (depending on area) pick up the entire pack for $250-$400.
Old 08-02-2008, 01:05 PM   #16 (permalink)
NES Collector
I didn't think about getting used nimh batt's I wonder how much they weigh? I plan on having 3 sets of the NICD packs so I'm hopping that the wires wont get hot & melt I've been so busy over the last week that I haven't posted any pic's of my progress I'm working on the bike today & hope to have it done. So I'll post some pic's later.
Miles Displaced By
Walking = 3.6
Old 08-09-2008, 09:01 AM   #17 (permalink)
NES Collector
Major Update
Bike is done Here's some pic's
Batt packs one open one closed, & one charger,
Inside batt box. I decided to use 42 D batt's instead of 40. A little extra power
Batt packs in bike
Completed bike.
The chargers have been a NIGHTMARE I ordered the 2A chargers, got them in. They sent me 1A ones so I called them & they said that they would send me the right ones. Then they send me the same ones! Called them back & was told (after much explaining) that the 2A ones were discontinued. Sooo I was back to searching for a charger. I found this one It is a great charger. Although I had to modify the packs. This charger will charge 1-24 cells & I have 42. So I had to make 2 24V 20A pack instead of 2 48V 10A packs. I ordered 2 of the chargers got them in on mon. but one had a broken LCD screen! So I sent the broken one back & ordered 2 more from someone else on tues. told them to send them out on wed. to get them by fri-sat. They called me & told me they were out of stock & wold be in on fri. WTF So I told them to send them out on fri Express mail so I hope to get them today.
Miles Displaced By
Walking = 3.6
Old 08-09-2008, 09:57 AM   #18 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
It looks great, except as jakemacd points out, the little wires soldered between the batteries should probably be quite a bit thicker or you will be losing a noticable amount of energy there. They should probably be as thick as the cable leaving the box. I suppose you could just test it at this point: Accelerate it at full throttle while feeling one of the small inter-battery wires, and if you burn your finger then make them wires thicker
I'm a bit jealous of the bike though
Old 08-09-2008, 03:24 PM   #19 (permalink)
NES Collector
I checked the wires & they don't heat up much at all. I just got back from killing the batts. went 27 mi. and the last 7mi was trying to kill the batts.
PS I got my chargers!!! So mon I'll be biking to work.
Miles Displaced By
Walking = 3.6
Old 08-10-2008, 11:44 AM   #20 (permalink)
Happy Hyper
That's fantastic Echomodder! You've got to be very excited and proud. What else can you tell us? Speed data for example. How much did this whole project cost you? I'm trying to decide between buying complete or building.
Summer FE options - Scooter, bike assist, etc friedlbug Alternative Transportation 16 02-20-2009 02:41 AM
ten reasons to bike instead of drive johnpr Alternative Transportation 58 07-03-2008 08:29 PM
Bike maintenance, how to do it myself to save some money NoCO2 Alternative Transportation 16 06-18-2008 12:01 AM
The Ultimate Commuter Bike NoCO2 Alternative Transportation 13 02-29-2008 01:45 PM
