Old 04-18-2011, 09:42 PM   #1 (permalink)
just saw this on ebay
20W monocrystal Solar Panel,Solar charger ,12V battery | eBay
i'm thinking to get a pair
Old 04-19-2011, 12:35 AM   #2 (permalink)
60+ mpg at posted speeds
California98Civic's Avatar
Black and Green - '98 Civic DX Coupe
90 day: 64.83 mpg (US)
Looks cool! Thanks for posting it. But it is 25" long, 11" wide, and almost an even inch tall. They would be a bit of a aero drag. Two would be $200 before shipping and then there would be other hardware to buy. But, of course, I'm thinking I want one or two as well. I wonder if they could be mounted on a trunk (where there is already plenty of draggy dead air). I wonder if I could keep people from stealing them?
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
Old 04-19-2011, 06:09 AM   #3 (permalink)
20W (or 40 if you buy two) is just about right to keep the battery topped off if you don't drive for a while, but you can't really run anything on that sort of power.. even a modest radio will consume more power than that I would think..
Old 04-19-2011, 08:21 AM   #4 (permalink)
Originally Posted by gabi View Post
What do you plan on using them for?
Old 04-19-2011, 08:25 AM   #5 (permalink)
Here is a list of how much power accessories draw, post a while ago (and for a Metro):
Tested: power draw of Geo Metro accessories & systems (volts, current/amps, watts)
What if the alternator were on a switch, as some have suggested on this forum? Under sunny conditions with a car that draws less power in general and none for accessories, put the alternator on a clutch and let the panel maintain. Let the battery recharge while the car sits at work all day. Use the alternator if necessary. Maybe?
Old 04-19-2011, 10:08 AM   #6 (permalink)
its actualy very thin,
2.5 milimeters
Old 04-19-2011, 01:04 PM   #7 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
try these, cheaper by a whole bunch
40W 2PCS 20W mono solar panels | 2X20 Watt Home Solar Panel | 12V Solar Panels
$180 with shipping. i have a pair of the 15W panels that i'll be putting on my Jeep's cargo box this summer
Old 04-19-2011, 02:27 PM   #8 (permalink)
Even if it's not enough to power the whole car, it should reduce the drag on the alternator pulley right? Getting supplemental charging power should help out some...
Old 04-20-2011, 12:24 AM   #9 (permalink)
its actualy very thin, 2.5 milimeters
Oh! I counted it as centimeters by mistake. 2.5mm is very thin alright.
Old 04-30-2011, 11:32 PM   #10 (permalink)
Gabi, did you end up buying a pair?
