Old 07-25-2009, 07:38 PM   #1 (permalink)
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
just tried out my new vac-gauge
at idle it reads 19-20 depending on alt load. At highway speeds it reads 12 inches in fourth gear and 17 inches in third gear. I would like to get some opinion of which gear i should cruise in because third will probably be easier for the engine, but fourth has lower revs. i just don't know if the lower revs are making up for the lack of vacuum. and i also realize that at lower revs the engine does not pull a high vacuum because it is not using that much air.
i know i will probably end up testing to find out anyway but i am wondering if anyone has been over this dilemma before.
oh and is 4 inches going uphill in fourth better than 7-8 in third?
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
Old 07-26-2009, 11:54 AM   #2 (permalink)
THE DODGE - '06 Ram 2500 ST
90 day: 22.64 mpg (US)
The Saturn - '08 Vue XR
90 day: 21.94 mpg (US)
The Odyssey Van - '011 Odyssey EX-L
90 day: 29.1 mpg (US)
When I had my toyota tacoma I used a scan gauge that would read out real time air flow through the MAF meter to get an idea on my fuel being used. Take your air flow in lb/min and divide by 14.7 which will give you the lb/min of fuel being injected. I used 14.7 as this is the air/fuel ratio my o2 sensor tried to keep the mixture. I did this at 60mph so it was 1 mile per minute to make calculation easy. At 0 vac in o/d it was using roughly 5lb/min air so it was injecting .34lb/min or mile fuel. Gas is around 6lb/gallon from what I remember so I divided 6 by .34 and came up with 17.65 which will be my mpg at 60mph and 0 vac. You can do this at any speed, gear, rpm, vac, boost, conditions, ect as long as you can hold the vac/boost steady long enough to get a reading. Hope this helps.
Old 07-26-2009, 03:09 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
IsaacCarlson -
Cool beans. It's a 2 for 1 because the gauge will also help you "gauge" the health of the engine :
CarloSW2
American Solar Energy Society
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 08:04 PM
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 04:53 AM
Econometer/Vacuum Gauge Installation Guide Johnny Mullet Instrumentation 76 07-29-2010 09:52 PM
SGII Horsepower gauge & related gauges RobertSmalls Instrumentation 3 03-03-2009 10:20 AM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-15-2008 12:04 AM
