Old 12-19-2016, 01:38 PM   #1 (permalink)
chips geo - '91 Geo Metro
90 day: 47.77 mpg (US)
Turtle Just an update on a 25 year old Geo
Its' been quite a while since I posted anything, so I thought I would let the world know how life with a Geo has been for me.
I originally purchased the Geo new in 1990 because I was commuting 53 miles one way to work. The Geo was the first car that i have ever had that got the gas mileage advertised.
The car is now 25 years old, just turned over 300,000 miles, still gets 45 mpg city and 56 mpg highway.
I am retired and work as a SCCA corner marshal, and actually camp in the car. I have removed the passenger seat, made a pvc frame to support sheet of plywood, and can stretch out comfortably.
The only problem I have to contend with is hills. Driving from the LA area to Button Willow or Laguna Seca requires going thru the Tejon pass/grapevine. As I usually cruise at 55 to 60 mph and stay in with the trucks, the car has a real problem with long grades. I have found that I have no choice but to down shift into fourth and stay in the far right lane. Once over the hill, I'll shut off the motor and coast.
I have done no real modifications to the car. Pizza disc hub caps. And removal of the steering wheel lock so I can turn off the ignition and not have the wheel lock.
I have emblazoned "51.8 mpg avg" on the back window to alert aggressive SUV and Mercedes drivers that, no I am not going to speed up, please dim your lights, and feel free to pass (all the while I am in the slow lane).
I enjoy reading the experiments and modifications other members are pursuing. I do not believes I have ever seen any other car (the Geo) become such a platform for modification except the model T and the original VW.
The Following User Says Thank You to geo1991 For This Useful Post:
JRMichler (12-29-2016)
Old 12-19-2016, 04:06 PM   #2 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Might be about due for a rebuild, since you're having trouble climbing hills. Check your compression (properly -- go to GeoMetroForum.com for the procedure) and let us know what you get. Unless you don't mind gearing and slowing down.
Old 12-19-2016, 04:42 PM   #3 (permalink)
25 yr old geo
Rebuilt the engine at 250,000 miles. Needed only rings and all new bearing while I was in there. And a valve job to clean things up. Clutch, etc.
