Old 11-06-2014, 10:25 AM   #201 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
between collar & shifter
Originally Posted by cowmeat View Post
There was enough room on mine to run the wiring in between the boot collar and the shifter, after I removed the entire center console of course. I threaded it through from the bottom side. There will be enough room to spare to snake the kill switch in there, too!
Aha! Thanks very much. I was wondering about doing that, and if the edge of the collar would cut into the wires, but apparently not. Your setup looks very neat.
Also I'm wondering where you got the black button?
Old 11-06-2014, 10:37 AM   #202 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
I'm not positive it won't ever short out, but I wrapped it in electrical tape first, so it'll last a while
I bought my set-up from Ebay, but I'm sure you can get the button type momentary from Radio Shack
The Following User Says Thank You to cowmeat For This Useful Post:
j12piprius (11-06-2014)
Old 11-06-2014, 04:10 PM   #203 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Yup, that's a big drawback of the Honda approach. If I was decelerating from higher speeds, or going down a hill, sometimes I would restart the engine and put it in gear to get regen. You end up in fuel cut mode, so you're still not using fuel, but only for as long as the RPM is in the right range, and regen is proportional to RPM. (So, sometimes I would downshift another gear to go raise RPM and get more regen and extend the fuel cut window.)
Do you know what the minimum RPM is for DFCO? A Google didn't show any definitive information.
