12-28-2009, 08:30 PM
Kinda ScanGauge w/o OBD
Hi there!
Is there any kinda equipment like scangauge for cars without OBD? No electronics at all.
The only one I know is the vacum meter.
Thanks!
12-28-2009, 08:44 PM
...beats walking...
...how far back year-wise are you talking about?
...if it's got electronic fuel injection of any sort (throttle body, manifold, etc.) then possibly the MPGuino is usable?
...if it's straight carbureted, you might have problems.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
12-28-2009, 09:14 PM
It's an old diesel engine from 1992 a ford fiesta 1.8D, I think the vacuum is the best solution right?
12-28-2009, 09:16 PM
Does the engine have a throttle? If not, a vacuum is pretty useless.
12-28-2009, 09:30 PM
...beats walking...
...as Daox states, a vacuum gauge is only usable if the engine is "throttled," since diesel engines are un-throttled with engine speed being controlled by injector fuel volume.
12-29-2009, 07:24 AM
But you can plug a vacuum meter on the brake vacuum lines right?
Won't it give the right data?
12-29-2009, 03:46 PM
...beats walking...
...yes, you could connect it there, but...
...no, because THAT vacuum I believe is a mechanically 'pumped' vacuum and not the diesels' manifold vacuum which is basically atmospheric pressure, ie: NO vacuum.
...you really want to measure how hard (or not) the engine is "working" not the barometric atmospheric pressure that tells you the altitude.
12-29-2009, 06:43 PM
But i fitted on a gasoline Seat Ibiza like i said and was working! It connects to the intake manifold! Right?
So can do nothing to scan anyway the engine?
12-29-2009, 07:01 PM
#9 (permalink)
12-30-2009, 11:45 AM
#10 (permalink)
aero guerrilla
A gasoline engine was vacuum in the manifold, that's just the way it works. This vacuum can later be used for brakes, etc. In a diesel there is no vacuum, so the brake assist has to be generated by an external pump powered by the engine. A diesel would work just fine without the vacuum pump, in fact it would have that much less load on its accessory belt or camshaft.
If your diesel has a turbo, then you can monitor the intake air pressure. It's not much, but always something.
Piwoslaw's Peugeot 307sw modding thread
