Old 09-08-2009, 05:26 PM   #1 (permalink)
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
3800 Sunfire - '02 Sunfire
knock sensor question
my chilton book says the sensor provides 8-10 volts to the ecm. when knock is detected that current is cut and timing is delayed up to 20 degrees. if i unplug the sensor that will cut voltage and timing will be delayed 20 degrees correct??? "loss of signal to ecm will cause constantly retarded timing"
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
Old 09-08-2009, 08:23 PM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
The check engine light will come on and stay on. I bet the ECM will just ignore the (non-)input from the knock sensor.
Old 09-09-2009, 01:19 PM   #3 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
It most likely works like my knock sensor does. It sends an alternating current through the sensor (or maybe produces it at the sensor), and checks for spikes in current. My connector wore loose once and every time it would disconnect it would throw a code and default to warmup mode (stock timing, rich mixture) which sucked gas horribly. I cut a replacement from the junkyard as soon as I could.
Winter daily driver, parked most days right now
Summer daily driver
Lean Burn all the way! brucepick Success Stories 67 04-29-2012 06:44 PM
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 49 03-25-2012 10:47 PM
Terrible mpg's = new interest in old ideas. mhmitszach EcoModding Central 258 11-16-2009 12:20 PM
Effect of fuel octane number on FE hummingbird EcoModding Central 32 10-28-2009 12:50 AM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
