Old 09-05-2009, 09:26 PM   #1 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Lancer Evo VIII hood vent
Hi,
I see that the (newest?) Mitsubishi Lancer Evo VIII has what appears to be a radiator heat vent in the top of the hood:
While it is not ducted, do you think this either helps the cooling and/or helps the aerodynamics?
Old 09-05-2009, 09:56 PM   #2 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
That is the previous generation Evo. I think it is to promote better flow through the rad & intercooler (you can see the intercooler in the lower grille) by letting the hot air out. Here is the latest generation http://pictures.topspeed.com/IMG/cro...a-6_460x0w.jpg
1996 Pontiac Bonneville SE 3.8L V6
Old 09-05-2009, 09:57 PM   #3 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Looks like cooling vents but for the intercooler not the radiator.
Old 09-05-2009, 10:00 PM   #4 (permalink)
wdb
lurker's apprentice
Scootie - '08 Fit Sport
90 day: 37.19 mpg (US)
That's pretty far from the newest EVO. They vent the hot coming off all of the various radiating thingies in the front of the car: radiator, AC condenser, (huge) intercooler. Dunno what it does for aero dynamics but it can't help but be good for the airflow across all of those gizmos.
Old 09-05-2009, 10:03 PM   #5 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
i believe this is the current one
Past Present Future?
Old 09-05-2009, 10:03 PM   #6 (permalink)
QuickLTD's Avatar
Where does the Turbo sit on that car? Is it inbetween the heat exchangers and engine block? Could be another huge source of heat right there.
Old 09-05-2009, 10:09 PM   #7 (permalink)
QuickLTD's Avatar
ah ha. see theres the heat..
http://www.airpowersystems.com/us_spec/evo/engine.jpg
Old 09-06-2009, 01:48 PM   #8 (permalink)
Josepha - '08 xD
Hi,
It's on the cover of the current Car & Driver, so it can't be that old?
Old 09-06-2009, 03:02 PM   #9 (permalink)
03 OZ - '03 Lancer OZ Rally
90 day: 34.67 mpg (US)
The Evo VIII was in production from 2003 through 2005.
Old 09-06-2009, 05:27 PM   #10 (permalink)
anthonye81's Avatar
Boxer - '95 146 1.7ie
90 day: 28.98 mpg (US)
Do turbochargers generate much heat in themselves? I guess the exhaust gas turning the turbine slows down and sinks more heat into the manifold/turbine assembly, but wouldn't the compressor side of the turbo be reasonably cool?
Anthony
Hood blanket swap Formula413 EcoModding Central 26 04-21-2011 11:58 PM
Custom glasfibre hood. Vekke Aerodynamics 8 06-15-2009 01:54 AM
Size of hood vent IkoIko Aerodynamics 28 04-22-2009 09:29 PM
