Old 04-01-2008, 06:30 PM   #1 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Larger/Heavier Flywheel?
I'm not sure if this has come up at all, but would a larger flywheel enhance FE?
The rationale is to sustain momentum, especially in city driving. (Kinda thought of this from reading an article on F1 racing, which then turned to recalling the hours of playing Gran Turismo and the "Lighter Flywheel" mod).
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 04-01-2008, 08:46 PM   #2 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
I don't think it'll help.
A flywheel is just going to help engine momentum, if you're using P&G then you don't really want more engine momentum.
Plus, from a more theoretical standpoint, a flywheel is an energy storage device. So you're storing your gasolines energy in kinetic form.
You're also losing energy through mechanical friction (of the flywheel) and you're losing energy every time you have to spin the heavier flywheel up to speed.
Same thing as lighter wheels really. I know there's some debate about lighter wheels, but I don't think anyone's in a big rush to go put heavier wheels on their car for the sake of FE.
I can appreciate the "whatever's good for racing is bad for FE" idea, but I don't think it applies in this case.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 04-01-2008, 09:41 PM   #3 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I would surely works, as its worked in the past. There was the golf ecomatic which used a flywheel to store energy, shut the motor down at stops and help relaunch the car with the flywheel momentum. The car acheived 16% better FE.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-01-2008, 10:02 PM   #4 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
1. It won't increase thermal efficiency - so if you're putting energy into a FW, it's not going to make running the engine any more efficient
2. At steady state - there's no difference
3. You can shift earlier without dropping rpm as much
4. You'll be able to go further while engine braking
So for 3 and 4, I don't see that big of benefit... If you're going to coast, EOC or throw it in neutral.... I don't see 3 as a big deal - 99% of the time you'll be in or out of gear, not shifting...
For 4, you can get the same benefit by adding dead weight to your car...
If the FW can be disengaged while not "charging" or "discharging" that energy... That would be beneficial for city driving
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 04-01-2008, 11:08 PM   #5 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
Good info guys -- just brainstorming...
_
_
Old 04-01-2008, 11:26 PM   #6 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Do a web search about flywheels.
There is some really interesting research using large flywheels as energy storage devices.
Think regenerative breaking where slowing down transfers energy into a big flywheel. It spins very quickly. The energy could then be transfered mechanically back to the wheels again, or could run a generator/motor to drive the car.
Really interesting stuff, wish I could think of a good web page about it.
Now this is not a flywheel as in the thing at the end of your engine. It is a HIGH RPM device made of fancy space age stuff.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 04-01-2008, 11:32 PM   #7 (permalink)
MechE
Old 04-01-2008, 11:56 PM   #8 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Lightbulb
not any help on the engine except for what Frank said.
But, off by itself sitting in a partial vacuum, hooked to only a motor/generator. a high speed flywheel, humming along from regen. don't need as big of engine.
Old 04-02-2008, 12:53 AM   #9 (permalink)
AndrewJ's Avatar
The main problem seems to be safety. Having a massive flywheel (the only kind that'll store enough energy) is quite a safety concern. That's the main problem with energy storage.
Batteries can short out.
Gasoline can blow up.
Flywheels can run off and trash everything.
Oh well.
Old 04-02-2008, 01:00 AM   #10 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
Kind of like the Medium-Duty Hybrid Trucks with hydraulic pressure build-up on slow-down/stop. The hydraulic fluid pressure gets the vehicle moving from a stop, then the hybrid system starts the Diesel engine and takes over. In this case the spinning wheel/disc acts as a "torque storage device"?
Instead of brakes (hey, sometimes ya gotta use them) the device would spin from momentum and store that energy to get started again. I'm sure other devices would take priority for installation.
RH77
_
_
flywheel. power bus DAN General Efficiency Discussion 4 10-02-2013 12:24 PM
