Old 05-22-2010, 09:00 AM   #41 (permalink)
Porno Music Producer
zhillz's Avatar
lolwut - '98 Civic EX
90 day: 47.5 mpg (US)
All oil filters hold the same much no matter the size. Be it internal diameters or the material inside, its regulated.
Old 05-22-2010, 10:15 AM   #42 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Man, I hope you can prove that... cuz I already know at least a handful of people on this site (as well as probably several hundred on BITOG) can prove otherwise.
You'd do best to either add some context to that post via the edit button, or add a reference to where you got that supremely ridiculous assertion.
Old 05-22-2010, 05:09 PM   #43 (permalink)
zhillz's Avatar
I re-read what i wrote and it does come off wrong. What I meant was per motor. Each motor has a specific filter which they code for you. They are all the same size and the amount they hold is very very close.
Old 05-22-2010, 06:00 PM   #44 (permalink)
Steve - '92 Festiva
That's a little better, but it's still not entirely accurate. Just because an engine was spec'd for a certain filter size/shape/etc doesn't mean others won't fit, even ones spec'd for different manufacturers.
For example, the 2.4L engine in my old Caravan used a very small filter, of which I'm not sure the part number. However, there was nothing keeping me from using either the filter that is supposed to go to an SRT-4 (same engine, different car), which has twice the capacity, or an even larger filter from Ford's small block lineup, the Motorcraft FL1A, which is billed as one of the largest filters on the market for basic application, and can hold something like .65qt of oil, compared to the one spec'd for the 2.4 Caravan, which only holds close to .25qt on it's own.
The actual filter cartridge diameter doesn't matter. If it fits in the space, and the gasket lines up like it should, you won't have a problem using it. Just because a filter is physically twice as large as your existing filter doesn't mean you can't use it. Compare the locations of the gasket ring (which can be done by putting the ring from one filter onto another one. If it fits, you're good to go.)
Old 05-22-2010, 11:12 PM   #45 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
My Jeep is spec-ed for a mid-size filter (same as the SRT-4, I think), as is the same Jeep with the 4.0 I6. With the 4.0, the larger filter (FL1A size, 5.0 Mustang filter) fits just fine, and bumps the oil capacity from about 6 qts to about 6.25 qts. Mine, however, will require relocation to use it, as it would hit one of the upper control arms for my front axle.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Excel PROVES why oil companies do not want more FE cars capn The Lounge 10 03-13-2010 11:24 AM
Larger diameter tires = better FE? JV-Tuga EcoModding Central 16 07-12-2008 10:45 AM
Book report: The Last Oil Shock by David Strahan AndrewJ The Lounge 0 01-16-2008 11:55 PM
