Old 01-26-2011, 05:46 PM   #21 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
Unless you really want to make alcohol find out what voltage the mower runs on and get a small 2nd battery. Then you can get some extra cable and a switch mount the 2nd battery run the cables to the switch then back to the original power connection. You now have a reserve battery that is there when you need it just by flipping a switch.
I move at the speed of awesome.
Old 01-30-2011, 04:10 AM   #22 (permalink)
Any thoughts on using the grass clippings in a gasifier verses a distillery? I've seen cars that run off of a gasifier, now that was charcoal or wood (biomass) But would grass be enough fuel to gasify and run a Mower motor? Better yet could a gasifier be minimized enough to fit on a mower?
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 02:29 PM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 12:22 PM
