Lawsuit: Prius recall for inverter software fix hurts fuel economy
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1519054183
An electrical engineer who routinely tracks the calculated MPG of his 2013 Prius noticed a significant drop in efficiency following a recall (software change) meant to fix a problem with overheating inverters in the cars. Toyota recalled 800,000 cars in the U.S. to apply a fix that may have reduced stress on the hybrid components by increasing the share of work done by the gasoline engine. When asked directly, the company hasn't denied this may have affected efficiency. A class-action suit is in the works: Quote:
Cherry on top: "a complaint by the dealer is now under review by the National Highway Traffic Safety Administration" because the problem can cause the car to suddenly enter "limp mode" (drastically reduced power output) without warning, including at freeway speeds. Source: Toyota Prius software fix may reduce fuel efficiency, experts say |
All things considered(lawsuit), wouldn't it be cheaper to just put in a bigger radiator for the inverter?
I dunno.
The article says the problem is solder joints on the IGBT's that crack due to heat stress/thermal cycling. Are they bathed in coolant? Or on a heat sink that's bathed in coolant? |
Sounds like they may have undersized the IGBTs and failed to deal with conducting the heat away. Solder joints are not typical places to dissipate power, so it must be the devices themselves that are dissipating too much power.
Hmm, my 2012 plug-in must use a different inverter since I was never notified about a recall.
I just have the usual Takata recall to complete as well as something about a high power fuse needing to be replaced. |
We haven't (yet) heard anything from Toyota about this recall for our 2014 Prius.
According to Toyota's most recent update, no Prius models are involved in the Takata recall. |
As an illustration of a possible counterargument, after I had the recall performed in early April 2014, I had a run of 9 tanks in a row at 60+ mpg, then one 59 mpg, then 6 more 60+, through October of that year. Using Enger's reasoning, the recall improved my car's fuel economy drastically! Except it didn't, because we haven't controlled any variables except the software update, so we have no way of knowing what effect it has on fuel economy by itself. Quote:
I don't know who's right here, but Enger has a lot to prove before I believe his claims. |
Given he's an EE who apparently tracks every tank (manually), I'd be inclined to give him the benefit of the doubt that he's comparing apples to apples. I'd be surprised if he made his complaint based on a single data point vs a long-term pattern.
But you know what happens when I assume ... So those are all valid questions. |
