Old 06-10-2009, 01:55 PM   #1 (permalink)
electricman
Lead-Acid Batteries Voltage Sag Formulas
Hi everyone, There seems to be a number of people responding to the Electric Car threads, so I wondered if anyone knows of some formulas that can be used to determine - ahead of time - how much the voltage will sag on a Lead Acid Battery, under some specific load or varying load?
While I have a PakTrakr - and a Woodward Enhanced PakTrakr Display - with Data Logging - I have a lot of empirical data, but no formula - maybe someone can look at the data and come up with a formula?
Electricfly - MyElectricfly.com and NoGas96volts
PakTrakr Multi Battery Monitor Battery Pack Monitor and
Thanks for you help, ahead of time! Robert
Old 06-11-2009, 12:35 AM   #2 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
Where are the data points? I could try to come up with a formula for voltage drop. It would at least be a function of current and temperature, and perhaps current and temperature and state of charge.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
Old 06-13-2009, 12:07 AM   #3 (permalink)
electricman
Data Points
I have the files from the display as it logs them in .csv format - as well as eddited and trimmed data files in .csv or excel spreadsheet formats. They can be quite long - since the paktrakr delivers one data line per second, so an hour would be 3600 lines. Luckily - the actual drive to work testing I am currently doing is just a copuple minutes, and I used to let the logger keep coing for the whole 8 hour shift - but lately started to simply log a few seconds before the actual drive and about 10 - 30 seconds or so after most times, so they are now just little 28kb files or so each trip.
I could make them posted in my electricfly site for access if you like?
Robert
Old 06-13-2009, 12:38 AM   #4 (permalink)
PaulH
ya! Post those buggers!
Old 10-08-2011, 10:27 AM   #5 (permalink)
electricman
One Weeks Summar Log of the Loads with Electricfly
Ok - here is a Summary Sheet - in Excel, and a Tabloid Sized (11" x 17") pdf print of the same data.
It is just a set of key highlights, but fishing though a table in Excel with 32,000 lines is no fun, trust me!
True - actually having a Packtracker on a battery, with the woodward display - logging the data, while doing a load test on a Lab Bench would be even more definative, and controllable, but here are some high points, and you can be sure the max current points and minimum voltage points are within a few seconds of each other for the most part.
By the way - Have you checked out EV Fest 2011 yet?
Robert
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 46 03-15-2012 07:21 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Video: Lead acid battery recycling MetroMPG Fossil Fuel Free 7 12-01-2008 04:43 PM
Guess: how many "labour hours" to make a conventional lead acid car battery? MetroMPG The Lounge 16 10-20-2008 03:57 AM
New batteries could lead to steep cost cuts for hybrids SVOboy General Efficiency Discussion 1 01-20-2008 09:02 PM
