Old 10-24-2009, 12:11 PM   #1 (permalink)
surly teady bear
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
lean burn=Lean of peak?
My understanding of air fuel mixtures comes from flying small aircraft. on takeoff the mixture is very rich as you are making lots of power and have poor cooling (due to low airspeed during climb) so extra fuel is used to cool. Once at the cruising altitude the throttle is pulled back, prop adjusted, then mixture leaned. I have been reading a bit about lean of peak running, and done a bit at high altitude (thin air means low power so not much heat created). When you pull the mixture back the EGTs go up a couple hundred degrees in some cases as extra fuel is no longer available to cool, and the mixture burning a little slower. Once you get to the peak EGT the mixture keeps coming out and the EGT and CHT temps will start dropping. So the leaner the engine is the cooler it runs. The only real limit is each cylinder will have a slightly different mixture so one will go too lean to support combustion and will have a misfire.
From what I understand the most hazardous point on the mixture continuum is just rich of peak EGT (exaust gas temp) once past that it seems pretty safe. In my plane on the ground I will lean for taxi to prevent fouled plugs when I lean enough and try to increase power over that needed for taxi I get hesitations and rough running due to the mix going to lean to burn.
Has anyone tried flow matching, intake and heads to get a leaner mixture in their cars?
http://www.avweb.com/news/pelican/182084-1.html Some interesting aircraft mixture information should be transferable to cars as an aircraft ICE is pretty similar to a ground crawler ICE.
Old 10-24-2009, 10:27 PM   #2 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 47.09 mpg (US)
I'm pretty sure that if you use custom ECU programming like MegaSquirt you can map your own rich/lean ratios. But you have to be pretty smart about it - too lean and you'll burn valves etc. I bet it can be done though.
The Honda Civic VX and the later Civic HX ('96 - '05) both had lean burn capabilities coded into their ECUs. I think some of the later Hondas also had/have lean burn but I can't say which ones for certain. I think Insight Gen 1 and Civic Hybrid?? Maybe others??
My own thinking is that lean burn lets you get max power out of a given qty of fuel because you're not sending a percentage out the exhaust unburned. Standard stoich ratio leaves some unburned fuel in the exhaust deliberately to keep the cat converter temp up - it combusts in the converter. The lean burn Civics keep the cat temp up by having the cat in the exhaust manifold (at least that's what my HX has) so it tends to stay pretty hot.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 34 10-10-2011 11:01 PM
lean burn rules~! coolwHip Introductions 42 10-01-2011 06:42 AM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
late 80's early 90's GM TBI advisory dcb OpenGauge / MPGuino FE computer 4 01-23-2009 04:14 PM
Running "Lean" with a Resistor Divider on the Air Temp Sensor steensn EcoModding Central 22 05-16-2008 10:11 AM
