Old 02-10-2011, 10:59 AM   #31 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...GOOGLE on "HCCI" or Homogenious-Charge Compression-Ignition.
...diesel-like operation at low-speed cruising with reversion to spark-ignition for controlled burn periods during accelerations.
...here's an old GM test article:
http://green.autoblog.com/2007/08/26...s-hcci-engine/
Old 02-10-2011, 11:52 AM   #32 (permalink)
The Beater - '99 Civic EX
90 day: 39.89 mpg (US)
HCCI engines are pretty cool in theory but would require a LOT of engineering to get it right, not to mention a heavy ass block to withstand the constant abuse of "detonation" the main principal there operating under.. Lean burns much more of a practical application.
I'm currently working on building a new engine for the beater. It all used parts that people were planning on throwing away or I had laying around. It'll be around 10-1 compresion with flat top pistons, a head that has much larger quench pads and much tigter piston to head clearence than a normal engine would have, it'll also be slightly less displacement (1.5L vs the 1.6L) thats currently in the car. It will have a vtec head that has a "smaller" camshaft profile than whats in the car now (when vtec is not engaged), and hopefully when in vtec it will make a little more power.
Ben
Old 02-10-2011, 12:27 PM   #33 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
A goodly chunk of the increase in efficiency of LOP is that you are opening your throttle farther for less vacuum.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 02-10-2011, 12:46 PM   #34 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Frank316, do you have an instant mpg readout to see what your mpg is at a 20:1 AFR at 50-55mph?
Old 02-10-2011, 12:51 PM   #35 (permalink)
No I do not, been thinking about building myself a mpguino, but haven't got around to it yet. And I relize running leaner lets you open the throttle more and decrease pumping losses, but it gets worse gas mileage past 20-1 than it does below it, not sure whats up with that but don't have the instrumentation to see everything thats going on. The cars converted to run obd1 so I can't use a plug n play scan-gauge or any of the like, the obd2 port doesn't work.
Ben
Old 04-22-2011, 09:56 AM   #36 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Any update Ben ?
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
