Old 06-25-2010, 02:13 AM   #61 (permalink)
o=o> the box - '97 850
90 day: 27.62 mpg (US)
Originally Posted by bgd73 View Post
I like the tiny marker lights.. I have two for no resaon, and they blow constantly.. will try some of the led ones.
did not know they existed..
that site showed I had 21 external lights.
I just ordered four "194".. two license plate at white and 120 angle, and two side marker 90 degree amber...
for every watt saved..how much is that in fuel? I know the headlights are the most dramatic, but to add up 21 external lights alone..yikes man, I don't think my 18 foot long delta 88 had that many lights...
there is little lights next to big lights on the old sube... trying to be pretty I guess.
This certainly isnt an accurate of a method, but it was enough for me to justify swapping my car to LEDs.
Givens:
1 Horsepower= 745 watts.
a "normal" produces approx 10HP to cruise at 60mph
Calculate how many watts you save by switching to LEDs and figure out what fraction that is of a HP. If you know how many HP it takes to cruise at 60mph you could make a rough guess at mileage gain.
Old 06-25-2010, 02:16 PM   #62 (permalink)
Dominion - '03 Beetle GLS TDI
90 day: 44.48 mpg (US)
Lilly - '99 Sentra GXE
90 day: 28.13 mpg (US)
I didn't see anyone say anything about this but I thought that I would share. I would recommend that anyone changing to LEDs go ahead and change out the flashers as well. The reason for this is that fast paced flashing experienced with LEDs or hyperflashing has been known to reduce the life of the LED bulb. I guess not a big deal if you enjoy spending a fortune on LED lights every couple years. However, for those money concious folk I would highly recommend getting a set of static flashers.
Old 05-18-2011, 04:44 PM   #63 (permalink)
4mula's Avatar
The Egg-Mobile - '94 Civic VX
90 day: 44.88 mpg (US)
I tried to read this whole thread and learned a lot, I recently ordered some leds of ebay and repaced running lights and liscence plate lights. but when I replaced the 1157 lights (dual contact) for front turn signal/running light and rear brake/running light I lost the running lights, so now only get tun signal and brake light
Here are a couple pics of the bulb if that helps, it should be dual contact, but maybe it's just cheap china parts. Anyone else had this problem or offer a solution? (Of course about to message the seller)
DIY LED Fish Tank Lights bennelson Saving@Home 20 12-28-2011 07:45 PM
My LED tail light conversion BrianAbington EcoModding Central 52 12-06-2011 06:42 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
improving mpg's with led taillights? GenX Rolla EcoModding Central 16 05-20-2010 08:57 AM
LED X-mas lights bennelson Saving@Home 10 12-04-2008 11:54 PM
