Old 02-11-2009, 07:17 AM   #1 (permalink)
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
Let's talk... AC!
Now I've read a lot of threads, especially Paul's thread about his DIY controller, and I realize that DC is a common motor/controller choice due mainly to budget...
But since I have no money for either, let us bloviate at length on AC setups, their workings and advantages.
I sort've get how a DC controller works, but not how an AC controller works.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
Old 02-11-2009, 08:24 AM   #2 (permalink)
Tobaloula Rusttbukkitt - '95 Ax Elation
90 day: 44.11 mpg (US)
Could you just not add a DC to AC converter (such as you would have in a car adapter) to the output from an ac controller? This seems really simple so it probably wont work.
Old 02-11-2009, 11:30 AM   #3 (permalink)
Converting from AC to DC or DC to AC results in major losses of power which is why it's not that simple to do in a project like this. Plus the components needed to handle that much power and heat would make it not worth the effort.
AC is a much better method of powering a motor (IMO) but your're right, the controllers require more electronics to handle the PWM at that power level so it's more expensive. Plus you would have to add a DC to AC inverter before the controller since there is no way to to store true AC.
Old 02-11-2009, 12:43 PM   #4 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
I've been thinking about designing a controller as well (or at least the control portion) and i've been thinking about AC. The gist of it is this - frequency of the wave determines rotation speed of the motor. rpm = 60* pole pairs * Hz. Amplitude determines current which relates to torque. I believe, however that there is also a relationship between rotation speed and the voltage required to get a particular amount of current - ie, at a stop, 60VAC will use more current than 60VAC at high speed.
From what I gather, the control portion is NOT hard, just the power portion is hard. Generating 3 AC waves from 3 PWM ports on a processor is easy. Relating RPM and throttle position to frequency and amplitude is "not hard".
I have been meaning to find a small fan to try to power with an audio amplifier (excellent DC to AC converter with variable freq and amplitude, optimised for under 85Hz)
Old 02-11-2009, 01:51 PM   #5 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
That's the trouble with AC is that everything is 3 times as complicated (expensive!)
Tom G. is converting a Dodge Neon to AC, using more or less off-the shelf industrial equipment. Of course he is also a electrical engineer and builds robots for fun.
I have had lots of questions from people about his project, but I am just NOT a knowlegeble guy when it comes to AC.
The next video I make with Tom will have to be about the AC drive he is going to be using in his car.
I do believe that the DC to AC inversion is a built-in feature of the drive that he is using.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 02-28-2009, 08:02 AM   #6 (permalink)
Max - '01 S-10 LS
The question that's on my mind is this. From Paul's controller build thread, I've gleaned that watts are meaningless to torque, and that the more amps you can cram into a motor the more torque you will get, at least as far as DC motors are concerned.
What I'd like to know is if AC adheres to this rule as well, or, can I double my torque by doubling my voltage, drawing the same amps but double the watts?
Would you trade your AC for some extra MPG?? Xringer EcoModding Central 38 10-21-2008 12:38 AM
AC cooling off the engine?? Xringer Aerodynamics 16 08-21-2008 07:12 PM
AC on the entire time and I got my best MPG average ever?? regor Hypermiling / EcoDriver's Ed 12 06-24-2008 01:55 AM
Running the AC during P&G - An observation Harpo Hypermiling / EcoDriver's Ed 21 04-14-2008 12:55 PM
AC Induction Motor used as Brushless DC? WaxyChicken Fossil Fuel Free 5 01-29-2008 10:26 PM
