Old 02-27-2011, 12:23 PM   #1 (permalink)
Zerohour's Avatar
Pooparu - '01 Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '011 Cooper
90 day: 36.4 mpg (US)
People Power - '86 Not Slim
90 day: 5.45 mpg (US)
Lexan and Fog Lights
Morning Guys and Gals
I have several mods already done with my Subaru, and I've been sitting on the material to make Fog Light covers.
Anyone familar with the Subaru Outback knows the fog lights are cupped into the bumper. I'm sure those pockets of air cause all kinds of turbulent flow (especially after the lower grill block).
My question is simple. Has anyone had experience with Lexan and it melting from head lamps or fogs? I will basically be cover the recessed fog light and trapping a pocket of air. I'm fairly confident that the 9005 bulb will not produce enough heat to do damage, but its always fun to ask.
This will also be my next, on-going project for the Subaru, so this can count as the offical thread.
Old 02-28-2011, 07:58 AM   #2 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
use them?
Do you even use the fog lights? With todays high quality headlights, I don't find any advantage in using my fog lights.
Old 02-28-2011, 09:46 AM   #3 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
Lexan has a REALLLLYYYY high reistance.
just not sure how high, but much higher than the fog thats 3-4 inches away. you can probably google it.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 02-28-2011, 12:02 PM   #4 (permalink)
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
Most new headlight covers are made from Lexan.
If you're worries, put a few small holes in the covers. This will let air circulate around, cooling them & shouldn't screw up aero dynamics that bad.
Don
Old 02-28-2011, 08:29 PM   #5 (permalink)
Zerohour's Avatar
Mini - '011 Cooper
Have you ever driving in real fog? Yeah they help quite a bit
Also not to bad on dark roads with tire eating potholes and, it never hurts to use them in the snow when it get into the 2"-3" in/hr.
Old 02-28-2011, 11:20 PM   #6 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
I found them completely useless, don't miss them at all.
Just cover them up!
Daily Driver
Winter Beast
Old 03-01-2011, 05:56 AM   #7 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Does opening the door to see where you are on the road, qualify as driving in real fog ?
I've found the foglights to be mostly useless.
In conditions other than fog or thick snow, it's illegal for me to use them anyway.
IIRC, Volvo was even going to delete foglights on future models.
Lifetime fuel consumption :
Old 03-01-2011, 06:54 PM   #8 (permalink)
Zerohour's Avatar
Mini - '011 Cooper
Well I will admit, if you driving down roads without lines, than fog lights are very helpful. But if you're on properly painted road in heavy fog, they give you some since of guidance. There are days, that in the morning, the valley will fill with fog. I leave my house and drive off into the mist. Doesn't happen often. But the painted lines in front of the car are basically the guiding lines. If not for them, you pretty much wouldn't be able to tell where you are going when you escape the tree lines and hit the open fields.
I always liked having some extra light in front with snow as well. There are times where you can flood the road with the low aimed fogs and see the road without using the headlights and blinding yourself in "high rate" snow fall.
I would say fogs are pretty useless for 98% of daily driving, but its that other 2% of year I'd rather have them.
Old 03-01-2011, 08:58 PM   #9 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Legacy Wagon 2.5 GT
Last 3: 23.78 mpg (US)
Maus - '94 Civic VX
90 day: 54.33 mpg (US)
Helga - '00 Jetta TDI
90 day: 57.68 mpg (US)
The bad part about putting a clear cover over the fogs is that they'll probably become so dirty & scratched over time that they'll eliminate any benefit the fog lights would have anyway... seems like you'd be better off with a removable cover (velcro, magnets, quarter-turn fasteners?) that you can quickly yank off for that 2% of the time you want to use the fogs... you wouldn't be going all that fast on those days anyway, so I'd guess the aero penalty would be minimal when the covers are off...
Old 03-01-2011, 09:14 PM   #10 (permalink)
Zerohour's Avatar
Mini - '011 Cooper
Well this would be the first attempt. We're coming out of winter now, so the chipping should be a minimum. I'm not too concerned with the lexan getting scratched over time. If last 2 years I'd be impressed.
Might be working on this in the coming days. I need to play with some heaters to hopefully form the lexan!
