Old 03-28-2009, 06:52 PM   #1 (permalink)
cottonfox's Avatar
April - '09 Aveo5 LS
90 day: 43 mpg (US)
Lights out EOC
I have a 2009, and when I turn the engine off the lights go out. Not too bad of a deal...except at night when it draws attention to my illegal actions / makes me not see the road for a second.
Anyone else having this issue on newer cars? Workarounds? (Would a kill switch solve the problem...I doubt I'll be able to wire one up...but would it maybe be worthwhile to learn?)
Additionally, and far more irritating, my fuel gauge sometimes goes to empty on the restart, and will stay there for some time. It's a bit unnerving and makes me worry since I just bought the thing in Dec.
Old 03-29-2009, 09:41 PM   #2 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 18.11 mpg (US)
Heep - '011 Grand cherokee Larado x
90 day: 19.31 mpg (US)
Da bike - '06 Shadow Vlx deluxe
90 day: 53.94 mpg (US)
let me guess chevy auto headlights?, try turning the switch on also.
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 03-29-2009, 10:30 PM   #3 (permalink)
cottonfox's Avatar
90 day: 43 mpg (US)
yep there are two different "on" settings. On, and super on (and then the brights). However, the lights are on/off regardless of the switch setting (when the car is on they are on, when off they are off). Kind fun...I guess.
Old 03-29-2009, 10:56 PM   #4 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
Are you referring to daytime running lights (which are ~90% as bright as low beams?), and then turning on/off the headlights? This affects the tail and marker lights, too, I think.
Old 03-30-2009, 04:08 PM   #5 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
You're saying it's impossible to turn the headlights on with the key out of the ignition?
Old 03-30-2009, 05:50 PM   #6 (permalink)
igo
igo's Avatar
Blue Saturn - '98 SL1 Base
90 day: 34.67 mpg (US)
My mom has an aveo and I have noticed the same thing. When you turn the key back to turn the engine off the lights go off (I think the parking lights stay on but not the daytime running lights). They will go back on when the key is turned formward but, that second the lights are off is anoying for sure.
Old 04-01-2009, 11:08 AM   #7 (permalink)
cottonfox's Avatar
90 day: 43 mpg (US)
Well, I could turn them off then back on. BUT, the main issue is for night driving. It would take just as much time as when I cut the engine, then put the ignition back to on.
Old 04-01-2009, 11:38 AM   #8 (permalink)
I'm still trying to make sure I'm reading this right: regardless of whether you have the "manual" headlight switch in the full "lights on" position (ie. not relying on DRL/automatic lights), when you switch the key from the "run" position back to the accessory position, the headlights will go out.
If that's the case, it's the first car I've heard of that does this.
Old 04-01-2009, 02:32 PM   #9 (permalink)
Weight Reduction
Drive Stick's Avatar
neon - '95 neon Highline
90 day: 37.7 mpg (US)
Subaru - '98 Legacy L Wagon
90 day: 29.94 mpg (US)
Saab - '98 900 S
90 day: 51.25 mpg (US)
Impreza 2.5i - '011 Impreza 2.5i
90 day: 24.06 mpg (US)
Send a message via AIM to Drive Stick
Same here, but a lot of Subaru's lights only operate with the key as well.. leading me to believe you are turning your key too far. You only have to switch it to accessory to shut the engine off, not to off position.
either you're turning the key too far, or this is a new issue we will have to work around with wiring up an independent headlight switch.
Old 04-01-2009, 04:12 PM   #10 (permalink)
cottonfox's Avatar
90 day: 43 mpg (US)
hmm never thought about the key-turning distance. Thanks! I'll see what I can do here.
[EDIT] No dice. the lights go out on ACC. I could try to engage the parking brake just a bit, this will keep the lights off as well. HOWEVER, still no help at night. [/EDIT]
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 02:57 PM
EOC and bad mpg... 97Cavalier Hypermiling / EcoDriver's Ed 10 05-05-2009 09:23 AM
Help me disable my daytime running lights for more fuel efficiency.... blackjackel EcoModding Central 7 07-27-2008 11:27 PM
EOC fuel usage ?'s reformed EcoModding Central 4 06-12-2008 09:51 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 02:18 PM
