Old 08-08-2019, 09:07 AM   #1 (permalink)
just joined..
Civic - '15 Honda Civic Tourer SR
ABT rs4 aero wheel - thoughts?
Saw these some time back .. joined up on this forum yesterday so thought i'd share (can't see that they've been discussed before?)
These are an option on the ABT (German tuning co) modified audi RS4.
Rather than a full cover (i'm assuming to allow brake cooling) they are essential a "ring" running around the outer edge of the wheel.
I did some research and found a technical paper that looked at various designs of wheel covers and this sort of design was very effective - i'll dig out that paper and post it here if can find it.
Other advantage of these vs. a full cover is that it keeps the lug nuts accessible so removing the wheel will be possible with the cover in place.
I might look to make up some similar covers for my wheels.
More info: https://www.abt-sportsline.com/compa...imited-series/
https://uk.motor1.com/news/260350/ab...heel-for-sale/
Oh, and they are a little pricey..
Looks like similar tech is used on the ABT formula e car:
https://www.motorsport.com/formula-e...7672/12797672/
Thoughts?
The Following User Says Thank You to rob.e For This Useful Post:
California98Civic (08-14-2019)
Old 08-08-2019, 09:10 AM   #2 (permalink)
just joined..
I think Daniel Abt probably says "they are aerodynamically efficient" but my german isn't good enough
Old 08-26-2019, 02:55 PM   #3 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
https://research.chalmers.se/publica...2_Fulltext.pdf
Is this the study? I found it in another of your posts. Great find! I was glad to see the authors address wheel venting and the total contribution to aerodynamic drag. I have experimented with fully covered rims on my Golf and found no measurable improvement. I suspect it interferes with flow out of the front wheel wells and creates greater lift/drag.
P.S. This probably should be posted in Aerodynamics. If you contact a moderator they can move it for you.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
rob.e (09-04-2019)
Old 09-04-2019, 09:22 AM   #4 (permalink)
just joined..
interesting i'm going to experiment with some covers that have a vent in the middle. It's on my list to do over the next few months (along with underbody, grill block etc..!)
Old 09-06-2019, 06:22 PM   #5 (permalink)
PSmodder lurker
Aero-rings, inspired by Formula E wheels. FIA had F1 wheel fairings/shrouds/covers in 2007-2009 but banned them for safety reasons. They came off at speed and aero studies have shown that the covers have "quite an adverse effect on the following car." https://www.motor1.com/photo/3141403...abt-aerowheel/
Old 09-09-2019, 11:35 AM   #6 (permalink)
just joined..
I'm planning to make up something that looks a bit like this:
... maybe just on the rears initially (thinking about brake cooling being more important for the fronts).
Old 05-16-2020, 10:40 PM   #7 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Did you ever get to make these? Would love to see the build.
Old 06-04-2020, 10:49 AM   #8 (permalink)
just joined..
sorry not been around here much lately - not done yet, it's still planned.
my car hasn't moved in 10 weeks.. (corona)
good for fuel economy though
California98Civic (06-04-2020)
