List of "typical" electrical loads in a modern car
We often talk about modding the electrical/charging system to reduce engine load. I happened across a quality source of power demands from various vehicle systems, and thought I would post it.
The list below summarizes the major subsystems (and loads) of the automotive electrical/electronic content of a modern (2006) automobile in the following categories:
Code:
Engine Management Power (W) http://i.cmpnet.com/automotivedesign...06/09/Max1.gif See more: Accessory overload threatens auto power budgets: Part 1, burgeoning loads and transients | Automotive DesignLine |
I don't know of too many vehicles with air suspension, plus GPS & Nav, plus electric power steering and brakes, plus all-electric everything...
That said, the basic point is still valid; there's a whole lot of electrical stuff in today's cars!! That's one more reason why I drive yesterday's. ;) -soD |
Thats a great list Metro. I always knew constant draw from an engine was around 25-30A. This proves it.
Ha! Maybe YOUR engine!
I'd still like to stick an ammeter on the Flea and get a true reading. I'll buy you a donut if it's more than 25A. |
Another item not mentioned ( Unless I missed it !) is some auto transmissions have an electronic control module which is always active.
Pete. |
I stuck an ampmeter on mine once. At idle with no accesories on, it was around 20amp's. At idle with absolutely everything that could be turned on, on, it was around 42amp's. A/C at max, doors open, high beam head lights, brakes, hazards, rear defrost, stereo cranked etc... I've just got an Escort, so it doesn't have many accesories at all.
Also, Svietlana has way more electronic gizmos than I need or even want: - heated side mirrors (turns on with rear window heating), - rain sensor for the automatic windshield wipers, - light sensor for the automatic headlights when it gets dark (of course here the lights must be on during the day too), - electrophotochromic mirror, turns dark when someone shines at you at night, - FM/GSM/GPS antenna, GPS is always looking for satelites even though I never use it, - 5 disc CD changer which doesn't work, but is making noises and gets pretty warm after 30 minuts of driving (I'm going to get rid of it soon). |
A few more I can think of. Many cars of the 90s+ had a body control module.
Power antenna, power headlight motors. Probably not significant but many had them. Heated backlight, does that mean rear defrost? Fog/driving lights is a good mention, since many vehicles have those. |
My Previa van draws 15-20A running without any other loads. I have an ammeter installed. The brake lights used to draw about 8 amps but I switched them to LED and now they don't even show up on the ammeter.
I P&G(lots of engine off coasting) with my 94 Corolla a lot. If I drive at night, with the headlights, brakelights, and the top 3rd brakelight all on, but with all other electrical stuff off, about how long could I coast before I either:
A) Do not have enough power to start my car with the key B) Have my lights dim to the point that it becomes a safety problem C) Damage my battery I have a 550(ah?) battery in relatively good condition, so let's assume 550 as a starting point. |
