Old 02-01-2012, 09:00 PM   #1 (permalink)
fastegg's Avatar
Lithium Battery.... bettery fuel economy ?
The guys selling lithium car batteries are claiming they provide better fuel economy.
I thought you could have 2 batteries, one standard lead starting battery, and a small lithium running battery. 4WD shops sell a battery isolator, a device that has both the starting battery and an aux battery conected.... When you start the car, it starts with the starting battery, when that is fully charged, it then switches to the aux battery and charges it. Now my theory is if you had this isolator in your car but the aux battery is a small motorbike size lithium battery that when fully charged, its voltage is in the high 13's (volts) so there is absolutely no load on the altinator... unlike having a 60lb lead battery always being trickle charged. There's a few guys in Australia selling lithium batteries and their claiming 5% better fuel economy. The reason i thought of having 2 batteries, one being a $50 lithium is that a full size lithium is $500-$700.
Does this theory/story have any validity ?
Old 02-01-2012, 09:11 PM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
This is currently (a pun! ) being discussed in another thread.
Old 02-01-2012, 09:47 PM   #3 (permalink)
fastegg's Avatar
MPGuni
Could you direct me to this thread ?...
Old 02-01-2012, 09:58 PM   #4 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Civic EPES: Alternator Delete Project (with additional lithium battery...)
It is easy to see what's currently being discussed by hitting the "recent posts" button at the top. It's also easy to find all related threads using the "search" function.
There's another thread(s) regarding using lightweight batteries too.
Old 02-02-2012, 01:44 AM   #5 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
Why not ditch the lead acid battery all together?
Lightweight Batteries
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
Old 02-02-2012, 02:15 AM   #6 (permalink)
fastegg's Avatar
Removing alternator
Ive just been reading about this guy that did his own tests with firstly just unpluging the alternator, then secondly taking the alt out all together.
He got about 5% unpluging the alt then 10% taking the alt out and running a shorter fan belt for the water pump. Then charging the batt up each day with a battery charger. So, if you used a lithium batt good for 2000 cycles ? and a weight saving of 15kg....
10% better FE and more power at the wheels.....
maybe using a 14 volt battery to avoid things playing up when volts drop...
