Old 03-06-2009, 07:30 PM   #1 (permalink)
Lithium battery? (For EOC users)
I found the following link:
Endless-sphere.com • View topic - YESA LiFePO4 engine start pack, Save 20% gasoline!!!
Perhaps a Lithium battery can help for those who frequently EOC?
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 03-06-2009, 07:41 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Not worth it, yet. The cost of lithium per Wh is still astronimcal compared to lead. Plus, I've been monitoring battery voltages lately. I only really have problems with voltage dropping too low when I have my headlights on. If its dusk/dawn I just turn on the running lights instead and voltages are fine. If I don't have any lights on I could coast forever.
Old 03-07-2009, 10:02 PM   #3 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
For new it's worth it provided the owner builds the ~14.4V pack themselves outa the DeWalt A123 cells or similar, at least compared to new. It should last ~20-30 years at least down to ~70-80% of the original capacity. While a new lead starting battery is pretty cheap at ~$50 for a smallish battery, it can only do, say, ~100 complete cycles or the equivalent, and since it'll only store ~.5kWh, that's ~$1/kWh stored. Deep cycle LA is a bit better at ~$.40/kWh stored, but it still isn't close to stuff like A123's cells that are ~10-25c/kWh stored depending on how low they're allowed to go in terms of capacity. It's kinda like the whole NiFe compared to LA deal. NiFe is also cheap per kWh stored, but since it's so much more expensive off the bat, most don't use it.
The Following User Says Thank You to roflwaffle For This Useful Post:
Thidj LeVert (03-14-2010)
Old 03-24-2009, 09:28 PM   #4 (permalink)
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
I've seen LiFePo4 prices at only double LA.
As a matter of fact, I posted about it...
Battery prices continue to plunge
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
Old 03-14-2010, 11:05 PM   #5 (permalink)
Écologue
Thidj LeVert's Avatar
Truce - '99 Taurus
90 day: 23.46 mpg (US)
QuébéCube - '92 Sportvan G20 Beauville
Send a message via MSN to Thidj LeVert
Hmmm I got my hand on a lot of NiFe battery packs. Looks old and dirty. They look easy to restore (Just like a metal tank with 2 bolts and a hole). I wanted to know if they are good to put into an EV. Here's the info on metal tag : Type: SV12 10 cells 120 amp. hours normal charge 24 amp for 7 hours. I would be grateful to any who could tell me also what is a dead battery (i.e. each battery of the pack shows 0.60 volt) i got them in a wood case, the number of batteries in each case varies, but they're all linked with a metal bridge (series). It belonged to a very old guy who used them for a windmill.
Edit :Theyre NiFe accumulator. some websites say it's good because of low discharge, some other says it's bad because of high discharge.. :?
Last edited by Thidj LeVert; 03-14-2010 at 11:18 PM.. Reason: found som info on net
Old 03-18-2010, 04:36 PM   #6 (permalink)
101% win
roflwaffle's Avatar
Toy - '82 Pickup
They're probably dead, but you can try and see if they take a charge. If they don't, I think replacing the electrolyte and trying again would be a good idea. They're supposedly heavier and less efficient than lead acid batteries so using them could make for a really slow/lossy NEV, but they're also supposed to be more durable. Great for backup power at a home IMO if the claims about their lifespan/maintenance are true.
Old 03-19-2010, 09:21 AM   #7 (permalink)
The Crimson Crawler - '04 Elantra GLS
90 day: 36.71 mpg (US)
I have a medium sized collection of Li-Ion cells from laptop batteries that I've been hoarding. If someone is after them to sort through and find good cells, I'm willing to send them out for the cost of shipping.
I have ~30 individual cells at this point.
Old 03-23-2010, 06:21 PM   #8 (permalink)
Tracy - '00 corsa
for the same energy storage, lithium batteries are 3 times lighter than lead batteries and some cells (like A123) are supposed to be 30C compared to 9C with lead. therefore your lithium battery would also be 9 times lighter. so you could shed about 15-20kg curb weight. if 100lb = 2% FE reduction, then you could save 1% of your fuel bill. the pay back time would be about 5 years on this basis.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 03-24-2010, 12:45 AM   #9 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
There is a company that produces lithium 12v nominal batteries for race cars - mostly for the weight savings. They've got built in BMA for cell protection (low/high voltage cutoff)
They contacted us at one point to see if we wanted to review one, but it never went anywhere. Price was prohibitive.
Old 03-24-2010, 09:51 AM   #10 (permalink)
Tracy - '00 corsa
cheap lithium cells are twice the price of lead, hight discharge rate cells that would be needed would be 4-6 times the price of lead. but you may be able to use less Ah capacity to get the same results. the right lithium battery might be only 2 or 3 times the old lead one.
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 42 03-28-2010 03:24 PM
Toshiba enters the lithium ion battery market SVOboy Fossil Fuel Free 6 03-21-2009 03:28 AM
LiFePo4 battery supplier ken102282 For Sale 23 12-16-2008 12:04 AM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 10:13 PM
"Sonata" Lithium Ion battery NeilBlanchard General Efficiency Discussion 0 09-08-2008 04:19 PM
