Old 02-17-2010, 06:17 PM   #1 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
little engine heater..self sustain.
I have a unique idea, and want to go ahead with it..but am wondering about the product:
it is only a 200w, but I only have a tiny oil pan..and want it to self sustain with a 450w invertor. A bonus for the idea is the pan is surrounded by a skid plate, no wind ever.
here is what underneath is. the coolant system holds just over a gallon, and the other heater designs for coolant are huge. Oil over rules water anyway, once any thermal is gained. The car takes .25 quart more oil than antifreeze, at 4.5 quarts.
I just need a heads up on the little heater in photo, stick it to the side of a pan, and hard wire it to an invertor inside the car. I have the engine burning hotter to an ignition upgrade, and cleaning, but it still needs a little bit more around zero degrees and colder.
Old 02-19-2010, 09:40 AM   #2 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
Think I have one of those and can tell you that that isn't enough heat to warm an engine overnite unless maybe it is in a garage and covered with a blanket. As far as running it while driving...doesn't make much sense to me.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
Old 02-19-2010, 11:07 AM   #3 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
Are you running a lifted EA81? I don't remember the skid plate being that steep.
On topic: I dont think thats enough power. I had an oil pan heater that was 250 watts and it didnt do crap.
Daily Driver
Winter Beast
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
Engine Insulation GdB EcoModding Central 5 11-30-2009 02:05 AM
An Engine Block Heater in San Jose Who EcoModding Central 20 07-28-2008 05:44 PM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
