Old 08-14-2008, 08:32 PM   #1 (permalink)
little help.. newbie mechanic metro valve cover
Hey Guys, quick question. I'm dumb and I accept your derision.
Now that thats out of the way:
SO metro 3 cyl valve cover. I have removed the 4 nuts and am now trying to remove the retention washers(?) underneath. It's not going so good. They look awfully like they're a part of the valve cover. I tried to dig underneath them with a screwdriver but I scored te valve cover up some and stopped immediately.
ANy thoughts here? I'm scared of damaging the valve cover. Apparently the 4 as yet undone head bolts are hidden by the valve cover so it's gotta come up.
Everything I've seen says strike washers off but I put a good gouge in the valve cover and just want a little reassurance.
Thanks in advance.
Old 08-14-2008, 09:16 PM   #2 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
On an engine they have been on there a long time the easiest way I have found is use a pocket knife to get under it and lift it up enough to get a pair of pliers to grab it and work it off with the pliers from there.
Or if you have some pliers with a good strong edge you might be able to grab them without using the knife and twist them a bit to break them free. They come off easier once you get them unstuck from the valve cover. A bit of scratching won't hurt the valve cover just don't gouge a huge scratch through it all the way to the stud.
My Convertible Metro XFI Plug in Hybrid Project build log
Old 08-14-2008, 09:58 PM   #3 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
After removing the nuts, use a good screwdriver or a chisel with a hammer and rotate them counter-clockwise until they un-thread from the stud.
Old 08-15-2008, 04:06 PM   #4 (permalink)
1991 Metro 1.0 Auto - '91 Metro Lsi Auto
90 day: 38.87 mpg (US)
On my 91 metro they appear to be metal, I used a scratch awl and hammer to unscrew them and I'm going to drill the threads out before they get put back on since it was a real PITA getting them off.
Old 08-25-2008, 10:23 AM   #5 (permalink)
Message to myself from three weeks ago (and to anyone else wanting the benefit of my hindsight)
1. The washers: Not actually metal. Really there's just a thin metal cover over a sort of hard plastic/rubber. Don't be fooled just because they look like a solid metal fastener.
2. What worked for me: Scratch awl and a small hammer. Angle the awl at a 45 degree angle to the surface of the washer halfway between the threaded post and the outer edge. Use the hammer to punch through the topmost metal (not difficult; tap, don't sledge). Tap the awl and drive the washer counterclockwise adjusting the handle of the awl to maintain the same relative position of awl to washer. Once you get them unthreaded far enough, it's finger work.
Do not waste hours trying to grab the edge of the washer with the tip of a succession of needlenose pliers and channel locks. This way lies madness.
Thanks, guys. I was just skerred. Once I gave it a solid whack and stopped worrying about the finish on the washer, it was easy-peasey.
Old 04-13-2010, 04:13 AM   #6 (permalink)
I remember myself damaging and then fixing the valve cover gasket set and bolts and for me it was no joke.. I had to use an extractor to back the bolt out of the hole then replaced it with a new one.
DIY - Valve Cover Painting SVOboy DIY / How-to 1 05-13-2012 05:01 PM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Geo Metro transmission question - what's under this cover? MetroMPG Off-Topic Tech 8 04-01-2008 11:07 AM
ATTN: METRO SWIFT OWNERS (with NO A/C) - Rear Canvas 'Flow Thru' Hatch Cover XFi For Sale 0 03-25-2008 06:59 PM
