Old 11-23-2009, 05:30 PM   #1 (permalink)
Just a Joe
Little Red honda Cub - Volted
A few nights ago I started on my newest eclectic conversion, this time it’s a 1981 Honda Passport “cub”. I found this sweet little scooter on craigslist for $150, not running and missing a some parts to the carb. My initial intentions where to replace the cab and get her running again, But I failed. Turns out I don’t know the first thing about small engine repair, and spent countless hours breaking things more so than fixing them. So I scraped that idea, and stripped her down lastnight. Always fun. Now my plan is add a 36 volt electric motor, which I salvaged from one of those cart pushers you see in the walmart parking lots. My plan is to have it up and running in a week, just in time to bet the folks over at honda working on the real electric cub.
Old 11-23-2009, 07:28 PM   #2 (permalink)
Eco Dreamer
Versa - '08 Versa SL Hatchback
Cool little project. Keep us posted.
What are the specs on that motor? Those cart pushers are pretty slow, they probably have decent torque though. Might have to play with the gear ratio a bit.
Old 11-24-2009, 09:53 AM   #3 (permalink)
Just a Joe
electric scooter motor
Motor was salvaged from a Quick Kart 2000 (walmart cart pusher) the original motor feed into a beefy transaxel. For whats left of the label on the motor, it looks to have been manufactured in 2004, by statute electric inc. rated at 36VDC. it's 5 inches and weight around 30-35 pounds. Not sure what kind of amperage it can handle but it seems to be a quality built motor. I took it apart for cleaning and to check the brushes, not to much ware. I plan on repainting the casing, but we can cross that bridge when we get there. I removed the electric motor from the transaxel. First isssue to solve is how to get a drive sprocket on it, the output shaft is a 3/4 inch twisted shaft. I don't think there are any standard sprockets that will fit this. Any Ideas?
Old 11-24-2009, 03:22 PM   #4 (permalink)
Just a Joe
Motor was salvaged from a Quick Kart 2000 (walmart cart pusher) the original motor feed into a beefy transaxel. For whats left of the label on the motor, it looks to have been manufactured in 2004, by stetute electric inc. rated at 36VDC. 5 inches and weight around 30-35 pounds. Not sure what kind of amperage it can handle but it seems to be a quality built motor. I took it apart for cleaning and to check the brushes, not to much ware. I plan on repainting the casing, but we can cross that bridge when we get there.
electirc scooter, honda, scooter conversion
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
2000 red 5-speed Honda Insight parts car $2,500/offers NTI V10 For Sale 1 12-07-2009 04:43 AM
Honda Cub Makes a Comeback (Sort Of) SVOboy EcoModder Blog Discussion 2 04-28-2009 09:41 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Honda sells its 60 millionth Cub SVOboy General Efficiency Discussion 2 05-24-2008 01:35 PM
